Yes, but you are probably confusing the OP with extraneous information.
>I'm showing what a Surface 2 Pro has in its INF directory. BTW I just found out I can pipe to ISE to have each one opened in it. That makes it even easier to check them
I am running a Surface Pro 2 with build 17134.167. There is an external USB HUB with a Dell monitor, mouse and audio connected to the HUB. After the last 1803 update, the display driver fails to load and the external display is not recognized, although it works. The Control Panel Device Manager also shows that the unit is not recognized as a Surface model with the keyboard and unit displaying caution icons. Associated drivers imply that they are for a Surface Pro 4. The system appears to work, but it has issues. All updates have been through automatic updates, so I do not understand the Surface Pro 4 designations.
I have tried to update drivers when allowed and that fails with the system telling me that the installed drivers are up to date.
Am I doomed to perform a reinstall, or is there another solution. Evidentially I have no recovery files, although I am sure that I made some.
NO. I am talking about the infs in the ZIP file.
I guessed that. I'm showing what a Surface 2 Pro has in its INF directory. BTW I just found out I can pipe to ISE to have each one opened in it. That makes it even easier to check them.
NO. I am talking about the infs in the ZIP file. Not the ones already on the
Surface.
> want him to just try using the inf's.
OK. I just checked those. I thought they were more parameterized.
PS>dir -Re *.inf -Fo -EA:SilentlyContinue |% {if (GC "$_" -EA:SilentlyContinue | sls "Surface") { echo $_.FullName } }
C:\windows\inf\errata.inf
C:\windows\inf\msux64w10.inf
C:\windows\inf\oem10.inf
C:\windows\inf\oem103.inf
C:\windows\inf\oem114.inf
C:\windows\inf\oem117.inf
C:\windows\inf\oem127.inf
C:\windows\inf\oem13.inf
C:\windows\inf\oem142.inf
C:\windows\inf\oem144.inf
C:\windows\inf\oem145.inf
C:\windows\inf\oem148.inf
C:\windows\inf\oem166.inf
C:\windows\inf\oem180.inf
C:\windows\inf\oem183.inf
C:\windows\inf\oem208.inf
C:\windows\inf\oem22.inf
C:\windows\inf\oem230.inf
C:\windows\inf\oem25.inf
C:\windows\inf\oem78.inf
C:\windows\inf\oem91.inf
C:\windows\inf\oem96.inf
PS>ise
Doublechecked to make sure there weren't any more in some subdirectories.
crawl, walk run. want him to just try using the inf's. if that does not work,
the next step AFTER that is to uninstall from device manager AND delete when
prompted but not reboot. install all from inf files and then reboot and see what
has changed.
>What would happen if he deleted the broken settings? CSPRODUCT and BIOS both have Delete as a possible function
