Surface Pro 2 system issues
2018-07-18T17:10:07+00:00
I am running a Surface Pro 2 with build 17134.167.  There is an external USB HUB with a Dell monitor, mouse and audio connected to the HUB.  After the last 1803 update, the display driver fails to load and the external display is not recognized, although it works.  The Control Panel Device Manager also shows that the unit is not recognized as a Surface model with the keyboard and unit displaying caution icons.  Associated drivers imply that they are for a Surface Pro 4.  The system appears to work, but it has issues.  All updates have been through automatic updates, so I do not understand the Surface Pro 4 designations.
I have tried to update drivers when allowed and that fails with the system telling me that the installed drivers are up to date.
Am I doomed to perform a reinstall, or is there another solution.  Evidentially I have no recovery files, although I am sure that I made some.
    2018-07-21T16:10:53+00:00
    I've downloaded the files previously, but as I mentioned, there is no .msi file for automatically loading everything.  The files included in the UEFI Firmware folder are as follows:
    surfaceprouefi.cat
    SurfaceProUEFI.inf
    SurfaceProUEFI_20500FA.cap
    There are also folders for EC and SAM.
  2. Barb Bowman 80,815 Reputation points MVP Volunteer Moderator
    2018-07-21T14:15:36+00:00
    if you download the latest zip file and expand it, do you find a UEFI subfolder?
    If yes, what are the contents? A screen shot would be helpful.
    I don't honestly know what might be irrevocably corrupt by installing the wrong
    UEFI bits or how it was even possible to do this.
    2018-07-21T13:30:36+00:00
    I ran the command and below is what the system reported:
    BiosCharacteristics={7,11,12,16,19,26,27,29,32,33,40,42,43}
    BuildNumber=
    CodeSet=
    CurrentLanguage=
    Description=108.1926.769
    IdentificationCode=
    InstallableLanguages=
    InstallDate=
    LanguageEdition=
    ListOfLanguages=
    Manufacturer=Microsoft Corporation
    Name=108.1926.769
    OtherTargetOS=
    PrimaryBIOS=TRUE
    ReleaseDate=20171206000000.000000+000
    SerialNumber=<Redacted>
    SMBIOSBIOSVersion=108.1926.769
    SMBIOSMajorVersion=3
    SMBIOSMinorVersion=1
    SMBIOSPresent=TRUE
    SoftwareElementID=108.1926.769
    SoftwareElementState=3
    Status=OK
    TargetOperatingSystem=0
    Version=MSFT
    • 0
    It is obviously different from yours, but doesn't tell me anything other than that.  As for exercising the Create function, I would need to understand that function before going there.
    2018-07-21T13:26:32+00:00
    Barb, if I could recall I'd go through the same process with the correct BIOS image.  Unfortunately the process I went through eludes me.  I most likely did a search for Surface Pro BIOS updates and loaded the latest version.  According to sites I have visited, you can manually update the BIOS in Pro 3 and Pro 4 units, but not any the precede those models.  I guess that's not entirely true but obviously you shouldn't.  Not sure why I was able to load a Pro 4 BIOS to begin with.  Seems like the loader should have done a simple test before allowing it to happen.  My problem now is to figure how to back out of this situation.
  5. Barb Bowman 80,815 Reputation points MVP Volunteer Moderator
    2018-07-21T09:58:18+00:00
    Exactly how did you do this?
    > I recently did an update to the system BIOS and somehow the BIOS I loaded was for a Surface Pro 4.
