Airpods Not connecting property to Surface Pro 10
2019-08-30T19:42:05+00:00
I can pair my airpods with my Surface book 2 laptop, however they will rapidly connect and disconnect. And when it says "connected", no sound will play through the airpods. I've tried looking up a couple of fixes online but nothing is working.
Surface | Surface Book | Sound and camera
2019-11-13T20:44:42+00:00
I had the same exact problem with the Airpods Pro. My problem, as you mentioned, was the the rapid flickering back and forth between Paired andConnectedwith the Airpods ultimately never connecting.
For me, the solution was to restart the whole process as follows:
  1. Place your Airpods or Airpods Pro back into the case > Close the case > Set the Airpods down.
  2. On your Surface computer > Settings > Devices
  3. Select Add Bluetooth or other device > Bluetooth
  4. Pickup Airpods Case > Open Airpods case (Don't remove Airpods) > Press/Hold button on back of Airpods case until the Airpods are located by your Surface computer.
Your Surface computer should be able to at least find your Airpods by following the above steps.
*This is where I started having the problem stated at the beginning*
Solution:
  1. Go to settings > Type "Device Manager" in the search box.
  2. Once Device Manager is open, select Human Interface Devices
  3. Locate Bluetooth Low Energy GATT complaint HID device > Right-Click >Properties
  4. Select the 5th tab called Power Management
  5. Locate the checkbox "Allow the computer to turn off this device to save power" and UNCHECK this box!
  6. RESTART COMPUTER! *(This is what ultimately fixed my problem)*
Hope this helps! Wish it wasn't this complicated but oh well ¯\_(ツ)_/¯
2019-12-11T22:53:18+00:00
I couldn't even find a "Bluetooth Low Energy GATT complaint HID device"  under Human Interface Devices, and any other Bluetooth options in the Device Manager didn't have a power management option. However, when I clicked on "Converted Portable Device Control device properties" under Human Interface Devices, I found the power management option and disabled it. My AirPods are working correctly now. I hope I'm not saying this too soon and that it's not just because I just updated my Surface, but I've had this problem for a long time and updates haven't fixed the problem before. Hopefully this will work for you. It's unfortunate we have to deep dive into our settings to get headphones to connect right.
184 additional answers
    2019-11-10T19:19:02+00:00
    I am having same problem with surface laptop i am able to pair air pod pro but it's not connecting. It show's connected for second and go's away.
    2019-11-10T15:49:08+00:00
    In the newer versions of Windows you will find the Power Management setting in Device Manager / Human Interface Devices / Bluetooth Low Energy GATT complaint HID device.
         Hi, the power management options isn't there when I clicked on my airpods. and this method didn't work. I couldn't find the "bluetooth low energy GATT complaint HID device" option either. Is there any other options? please let me know.
    2019-08-31T23:55:30+00:00
    Hi 1croarty,
    Thanks for reaching Microsoft Surface Community. I'm sorry to hear with regards on your Airpods. I do have a thread that could have the same concern as yours.
    https://answers.microsoft.com/en-us/windows/forum/windows\_10-hardware/why-wont-my-airpods-connect-to-bluetooth/64964feb-cc78-499d-8556-60d2b9d6bda1
    Just in case, this wont help you can try to check your Device Manager while your Airpods are connected, try to uncheck the thick box indicates "Allow the computer to turn off this device to save power"
    Device Manager> Bluetooth > Look for the Bluetooth that mark your Airpods > Right click and look for the tab "Power Management" then look for  "Allow the computer to turn off this device to save power" uncheck it.
    Please let us know if this helps. Just keep us posted..
    Please keep us posted.
    Regards,
    Edd
    Microsoft Surface Moderator
