Surface Pro 3 Power/Lock button not working properly after Windows Update
2014-06-27T19:12:41+00:00
So I have the Surface Pro 3, which I love, however after the most recent Windows update when I press the power button once it brings up the "Slide to shutdown" screen. I read that Microsoft fixed an issue with the power button just before the release but I didn't have an issue until after the update. So I am assuming that the recent update caused the same issue that they previously fixed.
Thoughts?
2014-08-09T19:39:15+00:00
ok so i figured out the problem. when i got to controll panal and go to program. and click turn window feature on and off.  and when i check hyper v (which allows me to have multiple power option like balance, high power, and high performance) and when they install the program then i get this problem with power butten. and no im not pressing down the power butten i just click it.  i think they need an update about that because i do need high performance for my surface pro 3 bucause on balance mode you cant use full potential. the cpu performance is limited and wifi succs beacuse they limit them. i know that microsoft promissis the 9 hours of batery life but its not rigt that they are limiting  the potential of the divice it self for the sake of the batery power usage.....  i unchecked the hyper v and the power butten works fine. but im stuck with low performance.... you guys need to update the software
2014-06-28T19:00:44+00:00
Thanks for the prompt replies! It would do it when I would click or tap the button for, what I would guess would be, 1 second. It actually quit doing it by the end of the day.
A little more information:
I installed the large updates and when they finished I almost immediately noticed the power button issue. It was late so I didn't want to look too much into the issue, so after trying to research exactly what the recent update was I powered the device off for the night. I use the Surface for work and school; while at work I noticed that it was still having an issue, which was quite annoying as I use it while assisting customers. So on my break I decided to look for a fix that I didn't find. I tried rebooting the device and shutting it down for a few minutes, but it was still acting up. I didn't have time to really look into a resolution; hence my post.
However, by the end of the day it stopped bringing up the "Slide to shut down" prompt when clicking the power button. I wish I knew why it had this problem and why it decided to start working.
Anyway, thanks again for the replies!
43 additional answers
    2014-08-20T19:03:52+00:00
    I am having a issue with the Windows button not working on my Surface Pro 3 and touch cover. The screen vibrates when the Windows button is touched on my Surface Pro3. Nothing has damaged the tablet. Or have I done anything internally (software or hardware) to alter the computer's original state.
    Please advise.
    2014-08-10T10:39:32+00:00
    "liontigerlk" - it's unfortunately documented that the Hyper-V drivers are not compatible with connected standby, which is why the power button is hibernating rather than sleeping. That's a lot different than the "forced shut down" that was being reported elsewhere, because there the "shade" comes down and forces a power off, vs. just "turning off" (and hibernating).
    Hyper-V, though, has nothing to do with the multiple power options. Those are available anyway. Hyper-V is for virtualization, which is typically used in either a server environment or when running emulators, as you do when developing software.
    So, if you install the development tools, that typically enables Hyper-V.
    I've got two configurations that are prompted for when I boot my Surface Pro 3 - a "regular" one, with no Hyper-V, and a "development" one, that turns Hyper-V on. That way, when I don't need to run the emulator, I still get Connected Standby - but the emulator is a mere restart away.
    This blog post will help you configure things, if you want:
    http://www.hanselman.com/blog/SwitchEasilyBetweenVirtualBoxAndHyperVWithABCDEditBootEntryInWindows81.aspx
    2014-08-08T20:01:21+00:00
    Hi liontigerlk,
    Thank you for your message, and I am sorry that you also have the same issue on your Surface Pro 3 where pressing the power button leads you to shutting down the device instead of letting it sleep. I fully understand your frustration and would love to assist you.
    • I see you have tried the 2 button shut down to no avail. Could you tell us what else you have attempted so far and didn't work?
    • Did this start happening after the latest update?
    • And to confirm, you are merely pressing the button and not holding it down, correct?
    Please let me know!
