Surface Pro 3 Power/Lock button not working properly after Windows Update
2014-06-27T19:12:41+00:00
So I have the Surface Pro 3, which I love, however after the most recent Windows update when I press the power button once it brings up the "Slide to shutdown" screen. I read that Microsoft fixed an issue with the power button just before the release but I didn't have an issue until after the update. So I am assuming that the recent update caused the same issue that they previously fixed.
Thoughts?
2014-08-09T19:39:15+00:00
ok so i figured out the problem. when i got to controll panal and go to program. and click turn window feature on and off.  and when i check hyper v (which allows me to have multiple power option like balance, high power, and high performance) and when they install the program then i get this problem with power butten. and no im not pressing down the power butten i just click it.  i think they need an update about that because i do need high performance for my surface pro 3 bucause on balance mode you cant use full potential. the cpu performance is limited and wifi succs beacuse they limit them. i know that microsoft promissis the 9 hours of batery life but its not rigt that they are limiting  the potential of the divice it self for the sake of the batery power usage.....  i unchecked the hyper v and the power butten works fine. but im stuck with low performance.... you guys need to update the software
2014-06-28T19:00:44+00:00
Thanks for the prompt replies! It would do it when I would click or tap the button for, what I would guess would be, 1 second. It actually quit doing it by the end of the day.
A little more information:
I installed the large updates and when they finished I almost immediately noticed the power button issue. It was late so I didn't want to look too much into the issue, so after trying to research exactly what the recent update was I powered the device off for the night. I use the Surface for work and school; while at work I noticed that it was still having an issue, which was quite annoying as I use it while assisting customers. So on my break I decided to look for a fix that I didn't find. I tried rebooting the device and shutting it down for a few minutes, but it was still acting up. I didn't have time to really look into a resolution; hence my post.
However, by the end of the day it stopped bringing up the "Slide to shut down" prompt when clicking the power button. I wish I knew why it had this problem and why it decided to start working.
Anyway, thanks again for the replies!
43 additional answers
    2014-07-07T05:10:23+00:00
    I'm still having the same issue. My surface pro 3 power button stopped working properly a few days ago when I installed the update. Often times pressing the button (tap) either does nothing or it brings up the slide to shutdown screen. If I do it enough, the screen will finally turn off, but then I can't get it to turn back on. Several presses later the surface will reboot.
    2014-06-29T00:45:56+00:00
    Great! I'm glad it works out for you.
    Thanks for replying back..
    2014-06-28T18:38:55+00:00
    Thoughts?
    Stupid question on my part here.  Did you simply power down the device?  Let it sit a few seconds and try again.... does the same thing appear?
    Sometimes these updates require a reboot.... even though they say they don't.  As a matter of protocol, I reboot after every update.... period.
