Surface Pro 3 Power/Lock button not working properly after Windows Update
2014-06-27T19:12:41+00:00
So I have the Surface Pro 3, which I love, however after the most recent Windows update when I press the power button once it brings up the "Slide to shutdown" screen. I read that Microsoft fixed an issue with the power button just before the release but I didn't have an issue until after the update. So I am assuming that the recent update caused the same issue that they previously fixed.
Thoughts?
2014-08-09T19:39:15+00:00
ok so i figured out the problem. when i got to controll panal and go to program. and click turn window feature on and off.  and when i check hyper v (which allows me to have multiple power option like balance, high power, and high performance) and when they install the program then i get this problem with power butten. and no im not pressing down the power butten i just click it.  i think they need an update about that because i do need high performance for my surface pro 3 bucause on balance mode you cant use full potential. the cpu performance is limited and wifi succs beacuse they limit them. i know that microsoft promissis the 9 hours of batery life but its not rigt that they are limiting  the potential of the divice it self for the sake of the batery power usage.....  i unchecked the hyper v and the power butten works fine. but im stuck with low performance.... you guys need to update the software
2014-06-28T19:00:44+00:00
Thanks for the prompt replies! It would do it when I would click or tap the button for, what I would guess would be, 1 second. It actually quit doing it by the end of the day.
A little more information:
I installed the large updates and when they finished I almost immediately noticed the power button issue. It was late so I didn't want to look too much into the issue, so after trying to research exactly what the recent update was I powered the device off for the night. I use the Surface for work and school; while at work I noticed that it was still having an issue, which was quite annoying as I use it while assisting customers. So on my break I decided to look for a fix that I didn't find. I tried rebooting the device and shutting it down for a few minutes, but it was still acting up. I didn't have time to really look into a resolution; hence my post.
However, by the end of the day it stopped bringing up the "Slide to shut down" prompt when clicking the power button. I wish I knew why it had this problem and why it decided to start working.
Anyway, thanks again for the replies!
43 additional answers
    2014-11-08T18:00:25+00:00
    Power it on, go to the Windows 8 start menu, hold down the power button until it completely turns off. Don't let go until it turns off, it should take a good 10 seconds or so. When you turn it back on, the button should be working again
    2014-11-08T02:58:09+00:00
    Has anyone else gotten this problem to go away? I've tried 2-button power up and that still hasn't worked. I can go into sleep by closing the keyboard, but the power button always brings up the 'Slide down to power down" and selecting sleep from the power options on the main screen usually do the same thing. I also notice that when I do get to sleep and hit the power button to wake up I get the same sort of thing and have to swipe up twice on the screen, which tells me something is wrong in the underlying operation here.
    2014-10-16T21:19:25+00:00
    Hello KristinBarnes,
    Thanks for reaching out to us. Have you tried a refresh of your device yet? This guide has more information on how to do it.
    Let us know if that helps.
    Best Wishes,
    Zack_T
