Unfortunetely I believe the only thing everyone can be rest assured is this is a widely known issue to a lot of customers. Microsoft should be (hopefully) working on it.
Surface Pro 6 i7 1TB Battery Drain from 100% to 74% when turned off
I seem to be plagued by a battery drain issue with the Surface Pro 6.
Here is a quick rundown:
7/6/19 I bought a Surface Pro 6 i7 1TB. This device turned out to have a defective screen so I took it in for a replacement on 7/27.
7/27/19 I am assigned (what I later discovered was a refurbished unit) a replacement unit. A few days after that I started to notice that when I leave it at 100% at night, unplug it, go to bed, and when I wake up in the morning it would only have 74% o 75% battery left! Also when it is 100% and I unplug it, take it with me to work, by the time I reach my office about 45 minutes later then turn it on it only has 74 to 75% battery left! I was able to observe this multiple times. I tried several troubleshooting steps to no success. I am not using hello cortana face unlock or anything fancy.
8/15/19 I went to a Microsoft Store to ask them to take a look at the battery drain issue, and they said they saw nothing wrong and suggested I factory reset the unit which I did when I got home! But the following day the same issue appeared!
8/16/19 I went back to the Microsoft Store and told them the issue has not gone away. They issued me a brand new Surface replacement. At last I thought that was the end of the issue. I left the unit charging overnight, and this morning it was showing 100%. Out of curiosity I wanted to find out if this unit would have the same issue so I turned off the device at 100%, unplugged it, then left it for a couple of hours. When I turned it back on the battery was showing 74%!!
At this point I don't even know what to do. If anyone has a solution to this problem please share, otherwise I have no choice but to make another trip to the Microsoft Store for a possible fourth replacement.
Here is the drop observed this morning -
| 08:11:51 | Suspended | 100 % | 47,150 mWh | |
| 10:13:56 | Connected standby | AC | 74 % | 34,960 mWh |
My entire battery report is below:
| 2019-08-1614:45:56 | Active | Battery | 47 % | 22,420 mWh |
| 14:49:23 | Connected standby | Battery | 46 % | 21,840 mWh |
| 14:49:23 | Suspended | 46 % | 21,840 mWh | |
| 16:22:26 | Connected standby | Battery | 46 % | 21,790 mWh |
| 16:22:26 | Active | Battery | 46 % | 21,790 mWh |
| 16:22:26 | Active | AC | 46 % | 21,790 mWh |
| 16:31:39 | Active | Battery | 50 % | 23,960 mWh |
| 16:31:51 | Connected standby | Battery | 50 % | 23,910 mWh |
| 16:32:52 | Connected standby | AC | 50 % | 23,870 mWh |
| 16:33:09 | Active | AC | 50 % | 23,950 mWh |
| 17:11:21 | Active | Battery | 70 % | 33,260 mWh |
| 17:12:11 | Active | AC | 69 % | 33,080 mWh |
| 19:42:15 | Active | Battery | 100 % | 47,690 mWh |
| 19:42:21 | Connected standby | Battery | 103 % | 49,200 mWh |
| 19:43:04 | Connected standby | AC | 103 % | 49,200 mWh |
| 19:43:18 | Suspended | 103 % | 49,200 mWh | |
| 19:47:02 | Active | AC | 100 % | 49,200 mWh |
| 20:22:00 | Suspended | 100 % | 49,200 mWh | |
| 20:26:51 | Active | AC | 100 % | 49,200 mWh |
| 2019-08-1707:52:00 | Suspended | 96 % | 47,150 mWh | |
| 07:57:23 | Active | AC | 100 % | 47,150 mWh |
| 07:57:23 | Suspended | 100 % | 47,150 mWh | |
| 07:58:28 | Active | AC | 100 % | 47,150 mWh |
| 08:04:00 | Suspended | 100 % | 47,150 mWh | |
| 08:07:48 | Active | AC | 100 % | 47,150 mWh |
| 08:11:51 | Connected standby | AC | 100 % | 47,150 mWh |
| 10:13:56 | Connected standby | Battery | 74 % | 34,960 mWh |
| 10:13:56 | Active | Battery | 74 % | 34,960 mWh |
| 10:13:56 | Active | AC | 74 % | 34,960 mWh |
| 10:14:18 | Active | AC | 74 % | 34,850 mWh |
| 10:16:26 | Report generated | AC | 75 % | 35,130 mWh |
2019-09-05T03:27:05+00:00 -
Barb Bowman 80,815 Reputation points MVP Volunteer Moderator2019-09-04T11:28:45+00:00 *I* understand this. I was pointing out to someone else that the August29th
firmware update had nothing to do with battery issues, that it was for something
else related to SSD's.
2019-09-04T11:06:22+00:00 Before windows and firmware updates, devices worked perfectly. Specific SSD drives aren't the problem.
Barb Bowman 80,815 Reputation points MVP Volunteer Moderator2019-09-04T09:56:15+00:00 I was told that the firmware had nothing to do with battery issues etc. but was
for specific SSD drives.
2019-09-04T06:05:53+00:00 So apparently there's a new firmware for Surface 5 & 6.I just did the update and it seems to have fixed the issue.UPDATE:: So apparently, it did not survive 2 shutdown / start.
The latest firmware does not fix the issue.
SurfacePro6_Win10_18362_19.083.29713.0
