After recent update, this problem is fixed on my SP6. It works perfectly now.
My Windows version is: v1903 18362.10014
Surface System Aggregator: 241.1.139.0
Surface UEFI: 234.2706.768.0
Surface ME: 11.8.50.3448
I seem to be plagued by a battery drain issue with the Surface Pro 6.
Here is a quick rundown:
7/6/19 I bought a Surface Pro 6 i7 1TB. This device turned out to have a defective screen so I took it in for a replacement on 7/27.
7/27/19 I am assigned (what I later discovered was a refurbished unit) a replacement unit. A few days after that I started to notice that when I leave it at 100% at night, unplug it, go to bed, and when I wake up in the morning it would only have 74% o 75% battery left! Also when it is 100% and I unplug it, take it with me to work, by the time I reach my office about 45 minutes later then turn it on it only has 74 to 75% battery left! I was able to observe this multiple times. I tried several troubleshooting steps to no success. I am not using hello cortana face unlock or anything fancy.
8/15/19 I went to a Microsoft Store to ask them to take a look at the battery drain issue, and they said they saw nothing wrong and suggested I factory reset the unit which I did when I got home! But the following day the same issue appeared!
8/16/19 I went back to the Microsoft Store and told them the issue has not gone away. They issued me a brand new Surface replacement. At last I thought that was the end of the issue. I left the unit charging overnight, and this morning it was showing 100%. Out of curiosity I wanted to find out if this unit would have the same issue so I turned off the device at 100%, unplugged it, then left it for a couple of hours. When I turned it back on the battery was showing 74%!!
At this point I don't even know what to do. If anyone has a solution to this problem please share, otherwise I have no choice but to make another trip to the Microsoft Store for a possible fourth replacement.
Here is the drop observed this morning -
| 08:11:51 | Suspended | 100 % | 47,150 mWh | |
| 10:13:56 | Connected standby | AC | 74 % | 34,960 mWh |
My entire battery report is below:
| 2019-08-1614:45:56 | Active | Battery | 47 % | 22,420 mWh |
| 14:49:23 | Connected standby | Battery | 46 % | 21,840 mWh |
| 14:49:23 | Suspended | 46 % | 21,840 mWh | |
| 16:22:26 | Connected standby | Battery | 46 % | 21,790 mWh |
| 16:22:26 | Active | Battery | 46 % | 21,790 mWh |
| 16:22:26 | Active | AC | 46 % | 21,790 mWh |
| 16:31:39 | Active | Battery | 50 % | 23,960 mWh |
| 16:31:51 | Connected standby | Battery | 50 % | 23,910 mWh |
| 16:32:52 | Connected standby | AC | 50 % | 23,870 mWh |
| 16:33:09 | Active | AC | 50 % | 23,950 mWh |
| 17:11:21 | Active | Battery | 70 % | 33,260 mWh |
| 17:12:11 | Active | AC | 69 % | 33,080 mWh |
| 19:42:15 | Active | Battery | 100 % | 47,690 mWh |
| 19:42:21 | Connected standby | Battery | 103 % | 49,200 mWh |
| 19:43:04 | Connected standby | AC | 103 % | 49,200 mWh |
| 19:43:18 | Suspended | 103 % | 49,200 mWh | |
| 19:47:02 | Active | AC | 100 % | 49,200 mWh |
| 20:22:00 | Suspended | 100 % | 49,200 mWh | |
| 20:26:51 | Active | AC | 100 % | 49,200 mWh |
| 2019-08-1707:52:00 | Suspended | 96 % | 47,150 mWh | |
| 07:57:23 | Active | AC | 100 % | 47,150 mWh |
| 07:57:23 | Suspended | 100 % | 47,150 mWh | |
| 07:58:28 | Active | AC | 100 % | 47,150 mWh |
| 08:04:00 | Suspended | 100 % | 47,150 mWh | |
| 08:07:48 | Active | AC | 100 % | 47,150 mWh |
| 08:11:51 | Connected standby | AC | 100 % | 47,150 mWh |
| 10:13:56 | Connected standby | Battery | 74 % | 34,960 mWh |
| 10:13:56 | Active | Battery | 74 % | 34,960 mWh |
| 10:13:56 | Active | AC | 74 % | 34,960 mWh |
| 10:14:18 | Active | AC | 74 % | 34,850 mWh |
| 10:16:26 | Report generated | AC | 75 % | 35,130 mWh |
Is there a release date for this fix yet? Glad there's a new SP7 but please fix my SP6 that I have had less than 1 year.
It's getting really annoying that my battery runs out if I try to use it for more than 2 classes. Also don't like seeing 74% battery after the device has been fully charged.
I realize the firmware has been released to some insiders but it doesn't seem guaranteed upon signup. Also, I would rather not take insider builds as I don't have time to troubleshoot or reinstall/reset my device.
Not released to general public yet. It is only available on Windows Insider Program.
Not official. Bugs free?
Do you update new firmware 241.1.139.0?
Please Microsoft! Help us!
Battery drain, surfaces devices "on" and "off". Dozens of complaints since August update.
Show respect to your customers.
