Thank you for the suggestions. Fortunately, everything looks clean but the battery life is still 3-4 hours on battery. Very disappointed with the advertised life on battery and actual. I knew actual would be less but was hoping for 8 and 6 as a min....
Surface Pro 7 (i7, 16GB, 512GB) - Battery Life?
I picked up a Surface Pro 7 on launch but I'm really struggling with the battery life, with light usage (a few office apps and a few tabs in Edge) I'm struggling to get more than 5 hours, even with Battery Saving mode on, brightness at around 20-25 and nothing running the back ground.
I've updated everything to it latest version, surely I should be seeing better battery life than this?
2020-06-24T10:50:41+00:00 -
2020-06-24T05:26:55+00:00 Trying running the below power efficiency diagnostic report and see what it tells you.
https://www.isumsoft.com/windows-10/get-power-efficiency-diagnostics-report-for-window-10-pc.html
Also, check for corrupted files by following the below:
- In the search box on the taskbar, type Command Prompt, and right-click or press and hold Command Prompt (Desktop app) from the list of results. Select Run as administrator, and then select Yes.
- Type DISM.exe /Online /Cleanup-image /Restorehealth (note the space before each "/"), and then press Enter. (Note: This step may take a few minutes to start and up to 30 minutes to complete.)
- After you see a message that says "The operation completed successfully," type sfc /scannow (note the space between "sfc" and "/") and press Enter.
- After you see a message that says, "Verification 100% complete," type exit.
https://support.microsoft.com/en-us/help/4026529/windows-10-using-system-file-checker
Finally did you instill the Windows 10 May 2020 update? That may be causing problems as well.
Hope the above helps...
2020-05-20T19:59:53+00:00 I've tried all the solutions provided here and still nothing worked for me... I'm not sure why Microsoft is ignoring this issue. Not sure if I made a mistake by buying the surface pro 7 i7...
we need a solution
2020-05-12T12:47:57+00:00 Companys have different methods for testing battery life and Microsoft's way is the worst, Let me explain:
1)my android phone doesn't count my phone usage while the screen is turned off even if I'm listening to music while my iPhone 7 does.
2)Microsoft runs any video at 50% brightness without any multitasking CPU usage as far as I read.
sadly I think the surface problem comes from the CPU power usage.
2020-05-11T17:53:47+00:00 I still can't find the update
