Slow wired upload speed vs Linux on same hardware
Dawid Oosthuizen 26 Reputation points
2020-09-09T05:18:31.053+00:00
Intel® Ethernet Controller X550-AT2, 10G network interface on ASRock Rack ROMED8-2T with AMD EPYC 7232P processor.
Windows 10 Pro for Workstations, 2004.
Latest Windows updates and Intel drivers installed as of 09/09/2020.
This machine is a dual boot, the above Windows version, and Ubuntu 20.04.
When doing a speed test, I get good performance from Ubuntu, but very poor uploads from Windows. This is on the same machine, the exact same hardware.
The WAN link is 1000Mbps down, 50Mbps up.
This is the Windows speedtest result:
This is the Ubuntu speedtest result:
I have tried to tweak the adapter's advanced driver settings in Windows, such as disabling LSO, etc. No luck, performance remains poor.
I've also noticed it on another PC running Windows 10 Pro, and a laptop running Windows 10 Pro for Workstations, both give the same poor upload performance. Whereas my other Ubuntu 20.04 Server machine, and also my phone connected via Wi-Fi, is getting good upload speeds.
I have even taken the Windows laptop and plugged it straight into my incoming WAN connection (bypassing router), and it still gets poor upload speeds.
Incidentally, when the speed test is running, I can see that the upload looks bursty on Windows, like it is only getting chunks of data here and there, while in Linux and on Android it looks the same as the download, the graph is drawn at a consistent high rate and with consistent high values.
Windows for business | Windows Client for IT Pros | Networking | Network connectivity and file sharing
  1. Gary Nebbett 6,536 Reputation points
    2020-11-25T13:52:36.467+00:00
    Hello Egoist,
    The receive window (in this upload scenario) is managed by the server; the Windows client has no influence over how the receive window is managed - it only has influence over its "congestion window" (and direct information about that window size is not available from a simple network trace).
    My nominal upload speed is 25 Mbps and the browser-based Speedtest reports 24.51 Mbps, so there is not much that needs explanation or tuning in my case.
    Looking at my network trace, Speedtest (browser version) used 4 TCP connections in parallel during the "upload" test. Reviewing the TCP Connection Summary for these connections shows something like this:
    Tcb = 0xFFFFDB87419D5AA0 // Transport Control Block address
    DataBytesOut = 12875970 // The number of octets of data contained in transmitted segments, including retransmitted data
    DataBytesIn = 5430 // The number of octets contained in received data segments, including retransmitted data
    DataSegmentsOut = 8830 // The number of segments sent containing a positive length data segment
    DataSegmentsIn = 102 // The number of segments received containing a positive length data segment
    SegmentsOut = 8837 // The total number of segments sent
    SegmentsIn = 3158 // The total number of segments received
    NonRecovDa = 0 // The number of duplicate acks (or SACKS) that did not trigger a Fast Retransmit
    NonRecovDaEpisodes = 0 // The number of duplicate acknowledgment episodes that did not trigger a Fast Retransmit
    DupAcksIn = 214 // The number of duplicate ACKs received
    BytesRetrans = 199140 // The number of bytes retransmitted
    Timeouts = 2 // The number of times the retransmit timeout has expired when the retransmission timer backoff multiplier is equal to one
    SpuriousRtoDetections = 0 // The number of acknowledgments reporting segments that have already been retransmitted due to a Retransmission Timeout
    FastRetran = 16 // The number of invocations of the Fast Retransmit algorithm
    MaxSsthresh = 273548 // The maximum size, in bytes, of the slow start threshold, excluding the initial value
    MaxSsCwnd = 390784 // The maximum size, in bytes, of the congestion window size used during "Slow Start"
    MaxCaCwnd = 310079 // The maximum size, in bytes, of the congestion window used during "Congestion Avoidance"
    SndLimTransRwin = 0 // The number of transitions into the "Receiver Limited" state
    SndLimTimeRwin = 0 // The cumulative time, in milliseconds, spent in the "Receiver Limited" state
    SndLimBytesRwin = 0 // The total number of bytes sent in the "Receiver Limited" state
    SndLimTransCwnd = 76 // The number of transitions into the "Congestion Limited" state
    SndLimTimeCwnd = 8838 // The cumulative time, in milliseconds, spent in the "Congestion Limited" state
    SndLimBytesCwnd = 6286884 // The total number of bytes sent in the "Congestion Limited" state
    SndLimTransSnd = 77 // The number of transitions into the "Sender Limited" state
    SndLimTimeRSnd = 6264 // The cumulative time, in milliseconds, spent in the "Sender Limited" state
    SndLimBytesRSnd = 5859134 // The total number of bytes sent in the "Sender Limited" state
    ConnectionTimeMs = 15157
    TimestampsEnabled = FALSE
    RttUs = 38644
    MinRttUs = 9623 // The minimum sampled round trip time, in microseconds
    MaxRttUs = 130243 // The maximum sampled round trip time, in microseconds
    SynRetrans = 0
    CongestionAlgorithm = CUBIC
    State = ClosedState
    LocalAddressLength = 16
    LocalAddress = 192.168.0.10:63097
    RemoteAddressLength = 16
    RemoteAddress = 195.49.6.4:8080
    CWnd = 52436
    SsThresh = 27798
    RcvWnd = 130438
    RcvBuf = 131400
    SndWnd = 390784
    Looking at the raw captured packets and correlating them with the ETW data, one can easily spot the 77 occasions when there was no data to send (the application had not called "send" fast enough) and the 76 bouts of congestion.
    Gary
  2. Egoist 1 Reputation point
    2020-11-22T11:25:13.483+00:00
    I am also dealing with the same issue. My download speed seem to hit max, but my upload speed stays at 1.0 mbps.
    As @GaryNebbett-6715 suggested, we can benefit from a pcap trace file. I tried analyzing the files after doing so and it seems to be that the windows scaling goes flat too early.
    upon googling to find if someone had similar problem, i found this post that exactly matches my scaling graph: https://serverfault.com/questions/608060/windows-tcp-window-scaling-hitting-plateau-too-early
    a github issue describe similar behavior that happens with curl: https://github.com/curl/curl/issues/1485
    I am still searching for a solution to this random issue, but i am afraid there might not be one at the moment.
  3. mensa84 6 Reputation points
    2020-11-13T09:57:55.847+00:00
    I don't know how to do that.
    Anyone else can do, who has the same problem?
    I am really sure, that is currently a bug, which should be fixxed by MS.
  4. Gary Nebbett 6,536 Reputation points
    2020-11-13T09:50:01.263+00:00
    Hello All,
    My suggestion would be to make a network trace of both scenarios and then compare them. For a problem like this, a short capture/snap length of each frame should be adequate (say 100 bytes per frame; tcpdump historically defaulted to a snaplen of 68 bytes but 96 is better when IPv6 might be in use). A trace covering a few seconds of transfer should be adequate.
    It does not matter if different tools are used for the capture in the different environments and different trace file formats are used (e.g. pcap, pcapng, cap, etl); just use whatever tools are available.
    One could then try to understand the differences; for example frame length, inter-frame gap, window size, etc.. Armed with that information, it would be easier to speculate about which settings might have an influence on the behaviour.
    An additional help would be an Event Tracing for Windows (ETW) trace of the Microsoft-Windows-TCPIP provider covering the same period as the network trace; this should give some insight into the congestion avoidance behaviour. Some tools can collect both the network trace and the additional ETW source in a single file (Microsoft Message Analyzer, for example, could do this).
    One way of creating a suitable trace is to use the following sequence of commands in a PowerShell window:
    New-NetEventSession -LocalFilePath $Env:TEMP\SlowUp.etl -Name SlowUp
    Add-NetEventPacketCaptureProvider -TruncationLength 100 -Level 255 -SessionName SlowUp
    Add-NetEventProvider -Name "Microsoft-Windows-TCPIP" -Level 255 -SessionName SlowUp
    Start-NetEventSession -Name SlowUp
    [run performance test]
    Stop-NetEventSession -Name SlowUp
    Remove-NetEventSession
    The %TEMP%\SlowUp.etl file contains the resulting trace data.
    Network traces could be made available via services like Google Drive with the corresponding URL posted here...
    Gary
  5. mensa84 6 Reputation points
    2020-11-12T13:51:00.857+00:00
    Any news on this? @Dawid Oosthuizen
