workaround for edge 154.0.4258.37 print to pdf not working
Jordan Rosenberg 45 Reputation points
2026-09-25T18:11:22.2766667+00:00
edge update appears to have broken print to pdf. is there any workaround?
Microsoft Edge: 154.0.4258.37
Works:
  • Physical printers
  • Send to OneNote
  • Edge "Save as PDF"
Fails:
  • Microsoft Print to PDF
  • Microsoft XPS Document Writer
  • Adobe PDF
Same virtual printers work correctly from Chrome and other Windows applications.
Edge debug log:
Uncaught (in promise) TypeError:
Cannot read properties of undefined (reading 'media_size')
source: edge://print/index.js
Followed by:
Printer: print_error_dialog.cc:63
Check your printer and try again. Printing failed.
Microsoft Edge | Other | Windows 11
  1. Eugene Kovtun 10 Reputation points
    2026-09-28T15:17:52.82+00:00
    Exact same problem for us - Edge 154.0.4258.37.
    Using Save to PDF for now.
  2. Lakshmisha K S 0 Reputation points Microsoft Employee
    2026-09-29T08:18:32.2066667+00:00
    Microsoft has documented a known issue in Edge version 154 affecting Microsoft Print to PDF. Temporary workarounds are to use Edge Save as PDF or roll back to Edge version 153. Microsoft is working to release a fix. https://learn.microsoft.com/en-us/deployedge/microsoft-edge-known-issues
  3. Kevin Van 5 Reputation points
    2026-09-29T03:24:09.3266667+00:00
    Same issue here on Edge 154.0.4258.37 (Official build), Windows 11. Started overnight 28–29 September 2026, after Edge auto-updated.
    Symptom: printing from Edge to Microsoft Print to PDF does nothing. No error, no Save As dialog, no file created. Print queue is empty and the printer shows Idle.
    What I tested:
    • Windows "Print test page" on Microsoft Print to PDF: works (Save As dialog appears)
    • Notepad → Microsoft Print to PDF: works
    • Firefox → Microsoft Print to PDF: works
    • Edge → Microsoft Print to PDF via Ctrl+P: fails
    • Edge → Microsoft Print to PDF via the system dialog (Ctrl+Shift+P): also fails, so the system-dialog workaround didn't help in my case
    • No extensions enabled; resetting Edge settings to default made no difference
    So the Windows printer, driver and spooler are fine. The fault is only in Edge handing the job to the virtual printer.
    Workaround that worked: open the PDF in another browser (Firefox) or a desktop app and print to Microsoft Print to PDF from there.
  4. Jonathan Mathes 0 Reputation points
    2026-09-28T15:27:47.76+00:00
    Exact issue here using the System Print Dialog
    Rollback to version 152.0.4191.77 for now
  5. Emma1-N 13,320 Reputation points Microsoft External Staff Moderator
    2026-09-26T01:36:55.9566667+00:00
    Welcome Jordan Rosenberg,
    Based on the details provided, you've already done some useful isolation. Since "Save as PDF" works, physical printers work, and the same virtual printers work from Chrome and other applications, the problem appears to be specific to the Edge print dialog when communicating with virtual PDF/XPS printers.
    A few questions before further troubleshooting:
    • Does the failure occur on all websites, including simple pages such as about:blank or a basic webpage like Bing?
    • Are you using multiple Edge profiles, and if so, does the issue occur in all profiles?
    • Have you tested whether the issue persists in an InPrivate window?
    In the meantime, please try these quick checks:
    1. Open Edge and go to edge://settings/reset
      • Select Restore settings to their default values
      • Restart Edge and test printing again
    2. Test with extensions disabled:
      • Open edge://extensions
      • Turn off all extensions temporarily
      • Restart Edge and test Microsoft Print to PDF
    3. Create a temporary test profile:
      • Go to Settings > Profiles > Add profile
      • Create a new local profile and test printing there.
    Looking forward to your update.
