Yes. Try these Windows steps in order:
- Make sure Bluetooth is turned on.
- In Windows 11: Start > Settings > Bluetooth & devices and confirm Bluetooth is on.
- Also check the taskbar quick settings and make sure Airplane mode is off.
- Check the hearing aids themselves.
- Make sure they are powered on, charged, and close to the laptop.
- Turn the hearing aids off, wait a few seconds, then turn them back on.
- If they are near a USB 3.0 device, move them farther away because unshielded USB devices can interfere with Bluetooth.
- Remove and pair them again.
- Go to Start > Settings > Bluetooth & devices > Devices.
- Select More options for the hearing aids, then Remove device > Yes.
- Pair them again.
- If they pair but do not stay connected or do not appear as an audio device, check Windows support for hearing-aid audio.
- Some hearing aids use Bluetooth LE Audio or other protocols that Windows may not fully support on a given laptop.
- If the PC does not support LE Audio, some hearing-aid features may not be available.
- In that case, a manufacturer app or approved adapter/accessory may be required.
- Run the Bluetooth troubleshooter.
- Windows 11: run the automated Bluetooth troubleshooter in the Get Help app.
- Update the Bluetooth driver.
- Open Device Manager.
- Expand Bluetooth.
- Right-click the Bluetooth adapter and select Update driver > Search automatically for updated driver software.
- Restart the laptop if prompted.
- Check Windows Update.
- Go to Start > Settings > Windows Update.
- Select Check for updates and install any available updates.
- If Bluetooth is missing or still fails, reinstall the Bluetooth adapter driver.
- Warning: uninstalling the adapter temporarily removes Bluetooth until Windows reinstalls the driver.
- In Device Manager, expand Bluetooth.
- Right-click the Bluetooth adapter and select Uninstall device.
- Shut down the laptop, wait a few seconds, and turn it back on.
- If Windows does not reinstall it automatically, open Device Manager and use Action > Scan for hardware changes.
If the hearing aids pair briefly and then show Not connected, or show under Other devices instead of audio, that usually indicates a compatibility limitation rather than a basic pairing problem. In that case, check whether the hearing aids support Bluetooth LE Audio and whether the laptop has the required Windows and driver support.
- Fix Bluetooth problems in Windows
- Fix Bluetooth connected but no sound issue on Windows
- Use a screen reader to fix Bluetooth problems in Windows
- My Oticon hearing aids will pair with my Microsoft laptop (with Bluetooth LE Audio enabled), but won't connect. Thoughts? - Microsoft Q&A
- Hearing aid connection to Blue tooth - Microsoft Q&A
- Adding a hearing aid to Bluetooth - Microsoft Q&A
