I HAVE TO MANY VIRIOUSS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Eaton, Calista 0 Reputation points
2026-09-17T20:59:54.87+00:00
I HAVE 100S OF VIRUSES AND KEEP GETTING BITCOIN MINERS!!!!!!!!!!!!!!!! PEASE HELP,,,, MY COMPUTER FROUM 2016 IS GOIGN TO DIEEEEEEEEEEEEEEEEEEE
signed,
your mom
Windows for home | Other | Security and privacy
  1. Ferdinand Nanalig 32,855 Reputation points Independent Advisor
    2026-09-17T21:35:51.1566667+00:00
    Hi, let me help you.
    Please follow the steps below to scan your machine further.
    Please also try Microsoft Safety Scanner: https://learn.microsoft.com/en-us/microsoft-365/security/intelligence/safety-scanner-download?view=o365-worldwide
    And follow these additional steps.
    Uninstall an unwanted application in Programs and Features.
    Go to Start, type Control Panel, then go to Programs and Features. In the list of programs, look for anything unusual or any application you don't recognize, right-click it, and uninstall it.
    Delete Temporary files on Windows.
    Tap the Windows Key, then R on your keyboard; in the Run box, type in %temp%, then press Enter.
    Once it is up, highlight all, then delete. If there is a filé open that can't be deleted, just skip it.
    I hope this helps.
    If the above scanner did not detect any, please use these 3rd party tools.
    Let's try downloading the free version of Malwarebytes; it is freeware that you can use to scan, detect, and delete viruses like the one you currently have.
    You can download the free version from this link
    https://www.malwarebytes.com/
    Once installed, please make a full scan. You may remove this software once you are done with it.
    You can also try an online malware scanner: https://www.eset.com/int/home/online-scanner/
    URL Disclaimer: Please read.
    Note: This is a non-Microsoft website. The page appears to be providing accurate, safe information. Watch out for ads on the site that may advertise products frequently classified as PUP (Potentially Unwanted Products). Thoroughly research any product advertised on the site before you decide to download and install it.
  2. Deleted
