How to fix - can't start your camera - error code 0xA00F429F
Della Tinsley 0 Reputation points
2026-09-17T17:46:00.2433333+00:00
How to fix - can't start your camera - error code 0xA00F429F - I have been in touch with MS and it may be a driver issue - the other error has shown that another app is using the camera
  1. Ferdinand Nanalig 32,965 Reputation points Independent Advisor
    2026-09-17T18:20:39.66+00:00
    Hi, let me help you.
    Have you tried a hard reset?
    Turn off the laptop.
    Unplug the charger.
    Remove all USB devices.
    If the battery is removable → remove the battery.
    Press and hold the Power button for 30–60 seconds.
    Reinsert the battery (if removed).
    Plug in the charger.
    Turn the laptop on.
