Processes in Microsoft 365 for setting up Office apps, redeeming product keys, and activating licenses.
Your Office installation may have become corrupted after the PC reset. In this case, try repairing the installation by following the steps below.
Instead of Quick Repair, I suggest trying an Online Repair to thoroughly repair any issues with the Office installation:
In the search bar, type Control Panel > Programs and Features > find Microsoft 365/Office > right-click it > select Change > then run Online Repair.
If the issue persists, you can use the Office Uninstall Support Tool (Uninstall Troubleshooter) to completely remove Microsoft Office from your device and then reinstall it:
https://aka.ms/SaRA-officeUninstallFromPC
Once you open the link, click Get Help. When the tool launches, select Yes, then click Next. Choose the option to uninstall Microsoft 365 and follow the on-screen instructions to complete the process.
To reinstall Office:
Go to https://account.microsoft.com/services
Sign in with the Microsoft account associated with your Office license.
Locate Microsoft Office and click Install.
Run the downloaded installer and follow the on-screen instructions.
Once installed, open an Office app such as Word or Excel and sign in with the Microsoft account associated with your purchase to activate Office.
