how to fix when it says no device found for output or input
Tina Cribb 0 Reputation points
2026-09-15T23:30:21.7966667+00:00
i have no sound and when I troubleshoot the issue it says my laptop has no device for output or input so I also have no mic
  1. Emma1-N 12,985 Reputation points Microsoft External Staff Moderator
    2026-09-18T08:04:14.38+00:00
    Welcome Tina Cribb,
    Thanks for reaching out to Microsoft Q&A Forum. I understand that your Windows 11 laptop shows "No output device found" and "No input device found," resulting in both audio and microphone functionality being unavailable.
    Could you please confirm:
    • Did this start after a Windows update, driver update, or any recent system change?
    • In Device Manager, do you see any warning icons next to Sound, video and game controllers or Audio inputs and outputs?
    In the meantime, you can try these steps:
    Option 1: Check the Windows Audio services
    • Press Windows + R, type services.msc, and press Enter
    • Locate Windows Audio
    • Verify its status is Running
    • If it is stopped, right-click it and select Start
    • Also verify Windows Audio Endpoint Builder is Running
    Option 2: Run the Hardware and Devices troubleshooter
    • Open Command Prompt as Administrator
    • Run: msdt.exe -id DeviceDiagnostic
    • Follow the on-screen prompts
    Option 3: Reinstall the audio driver
    • Right-click Start and select Device Manager
    • Expand Sound, video and game controllers
    • Right-click the audio device and select Uninstall device
    • Restart the PC and allow Windows to reinstall the driver
    Option 4: Check for system file corruption
    • Run: sfc /scannow
    • After it completes, run: DISM /Online /Cleanup-Image /RestoreHealth
    If the answer is helpful, please click "Yes". If you have extra questions about this answer, please click "Comment".
  2. Ivan B 124.1K Reputation points Independent Advisor
    2026-09-16T00:03:35.3233333+00:00
    Hi ,
    Search for msinfo32.exe in the search bar, take a screenshot, and post it here so we can see the correct laptop model or desktop configuration.
    Can you access Device Manager, take a screenshot, and post it here?
    Thanks.
