In Share Point I am using =IF( OR( and unable to save the formula.
Sachin Sadalage 0 Reputation points
2026-09-15T14:03:04.3466667+00:00
In Share Point I have a 'Review Type' choice column.
In Share Point I have a '% of NF errors' calculated column.
I want to show percentage only when 'Review Type' is selected as 'QA Audit', 'Escalation', 'TL audit'
and I am using formula
=IF (
OR ([Review type] ="QA Audit",
[Review type] ="Escalation",
[Review type] ="TL audit"),
[Total no of Non-Fatal]/ [Number of items checked],
**Unable to save this formula and getting error as Sorry, something went wrong
My other column formulas are working correctly.
Please check this and suggest.
Microsoft 365 and Office | SharePoint | For business | Windows
  1. Ruby Nguyen 2,130 Reputation points Independent Advisor
    2026-09-15T15:15:35.3466667+00:00
    Good day Sachin
    I understand that you want the % of NF errors column to calculate a value only when Review Type is QA Audit, Escalation, or TL audit.
    Please start with these steps:
    Please note that I created and tested these formulas in a lab environment based on the information provided. Since SharePoint configurations, column settings and list structures can vary between environments, the formulas may work successfully in my test environment but behave differently in yours.
    Open your SharePoint list and go to List Settings.
    Select the % of NF errors calculated column.
    Remove the current formula.
    Enter the formula below as a single line:
    =IF(OR([Review Type]="QA Audit",[Review Type]="Escalation",[Review Type]="TL audit"),[Total no of Non-Fatal]/[Number of items checked],"")
    Set The data type returned from this formula to Number.
    Format the result as Percentage and save the column.
    If the formula still doesn't save, use the nested IF version instead:
    =IF([Review Type]="QA Audit",[Total no of Non-Fatal]/[Number of items checked],IF([Review Type]="Escalation",[Total no of Non-Fatal]/[Number of items checked],IF([Review Type]="TL audit",[Total no of Non-Fatal]/[Number of items checked],"")))
    Please also verify the following:
    Review Type is a single choice column.
    The column names in the formula exactly match the column display names in the list.
    Total no of Non-Fatal and Number of items checked are numeric columns.
    The formula is pasted without any extra formatting or special characters.
    This should help identify whether the issue is related to the formula syntax, column configuration, or column naming.
    If you have any questions or need further support, please don’t hesitate to reach out at any time.
    Thank you for your patience and understanding.
    If you have any extra questions about this answer, please click "Comment".
