A group of Microsoft Products and technologies used for sharing and managing content, knowledge, and applications.
Hello @Minhaj Maqsood
Since your scenario involves integrating Power Automate with the Decibel API, I recommend posting your question in the Microsoft Power Platform Community Forum Thread. This platform is specifically dedicated to Power Automate and is supported by a knowledgeable group of experts and partners who regularly contribute and share insights.
I suggest creating a new topic in the Power Automate Community rather than posting in the Microsoft Answers forum. The Answers forum primarily focuses on Microsoft 365-related concerns and has limited resources and expertise in Power Automate. By posting in the correct community, you’ll likely receive quicker and more precise guidance.
However, I found some information that could be helpful for your scenario. You should enable both Secure Inputs and Secure Outputs in your flow to prevent sensitive information from being exposed in the run history, logs, or audit records. This helps enhance the privacy and security of your data. For more details, please refer to Secure data used in cloud flows - Power Automate | Microsoft Learn
Regarding the HTTP response details when an error occurs, Power Automate typically captures and displays the error response returned by the Decibel API. Therefore, I recommend checking with the Decibel API support team to confirm whether their error responses may contain sensitive information, such as API keys or other confidential data. This will help you determine whether additional measures are needed to protect sensitive information within your flow.
Thank you so much for your understanding.
