Configuring preferences and options in Outlook.com
If Outlook on the web is open in a browser, right-clicking the page itself will not pin it to the Windows taskbar. Install it as an app first, then pin or launch it from the taskbar.
In Microsoft Edge:
- Sign in to Outlook on the web or Outlook.com.
- Select Settings and more.
- Select Apps > Install this site as an app.
In Google Chrome:
- Select Customize and control Google Chrome.
- Select Install Outlook.
After installation, Outlook can be pinned and launched from the taskbar like a desktop app.
If the goal is to pin the Windows Outlook app instead, open Start, type Outlook, right-click it, and select Pin to taskbar. If both new Outlook and classic Outlook are installed, pin the specific one needed, such as Outlook or Outlook (classic).
