billing issue
Louise Lafleur 0 Reputation points
2026-09-14T15:20:26.68+00:00
I ordered 2 MS365 packages by mistake...I need to cancel one. Please provide telephone number.
Microsoft 365 and Office | Subscription, account, billing | For home | Other
  1. DaveM121 933.9K Reputation points Independent Advisor
    2026-09-14T15:55:29.4+00:00
    If you purchased two Microsoft 365 yearly subscriptions direct from Microsoft, that has most likely pre-loaded your Microsoft 365 subscription for two years, and if you try to cancel the subscription, you may loose both subscriptions and you may only be refunded for the one subscription.
    Log into your Microsoft account on this link and check the expiry date on your Microsoft 365 subscription is that listed now as expiring in 2028?
    https://account.microsoft.com/services/
    If so, this forum is just a user to user forum, no-one here has any account access, you will need to contact Microsoft Support directly, try using this method to contact their support.
    Go to this link: https://support.microsoft.com/contactus
    Select Microsoft 365
    Click 'Get Home Support'.
    In the box provided, type billing.
    Press Enter, then on the next page, scroll down and click 'Sign in to Contact Support'.
    Navigate to Microsoft 365 and Office - Manage my Subscription.
    Select the 'Chat with support agent in web browser' option
