Microsoft 365 features that help users manage their subscriptions, account settings, and billing information.
I recieved support and was able to make the payment.
Hello. I have an Azure account created in Canada a few years back. I accidentally use its service from outside the country. Now there's a invoice in Canadian dollar and I can't make any payment using other credit cards from outside Canada. I can't send a support ticket as it keep sending me nonsense solutions without allowing me to access a person. I'm hoping to solve the problem or I'll ignore the account for good.
AI answer
For this scenario, the supported path is to open an Azure billing support request and avoid the portal suggestion loop.
Billing and subscription management support is available for billing issues, and the context indicates this route is used specifically when payment problems or locked invoices cannot be resolved directly in the portal.
If the card itself is being declined, the documented checks are:
If paying by card continues to fail and this is for a business, Azure also supports requesting invoice payment by wire transfer. To request that change in the portal support flow, use:
If you’re paying a Microsoft invoice from outside the U.S., I’d recommend checking the billing account’s country/region and available payment methods first. Microsoft’s billing support can also confirm which payment options are supported for your location if the payment keeps getting declined.
