HOW DO I CHANGE MY PERSONAL VAULT PIN?
KIRST M 0 Reputation points
2026-09-13T14:47:51.9133333+00:00
I do not seem to be able to find the right place for me to change my Personal Vault login as opposed to my device PIN or Password for Onedrive overall. Any suggestions?
Microsoft 365 and Office | OneDrive | Other | Windows
  1. EmilyS726 266.9K Reputation points Independent Advisor
    2026-09-13T15:26:03.2033333+00:00
    Personal Vault does not have its own separate PIN on Windows or OneDrive.com.
    If Personal Vault is asking for a PIN on the PC, that is the Windows Hello PIN for that device. So, if you want to change it, you would have to change it via Windows Settings > Accounts > Sign in options. But that changes the PIN for your device too.
    So, if you are asking for a specific unique separate PIN just for Personal Vault, that's unfortunately not possible. Sorry.
