What is usually happening is inaccurate location detection, not hacking.
Windows and Microsoft services can estimate location using GPS, nearby Wi‑Fi access points, cell towers, and your IP address. That means the detected location can be wrong, sometimes by a large distance. Some apps and services also use IP-based location, which can show a different state or city.
What to check in Windows 11:
- Open Start > Settings > Privacy & security > Location.
- Make sure Location services is turned on if location-based features are needed.
- In the same page, check whether apps are allowed to access location.
- Under Default location, select Set default and set the correct location on the map or type the address, then select Save.
If the saved location is wrong and needs to be reset:
- Go to Start > Settings > Privacy & security > Location.
- Under Default location, select Set default.
- Clear the address box and select Save to remove the default location.
- Then enter the correct location again and save it.
If location history is involved:
- Local storage of location history and its settings were removed in March 2025.
- If signed in with a Microsoft account and location services are enabled, location may be periodically saved in the cloud.
- To clear cloud-stored location history associated with the Microsoft account, go to account.microsoft.com, select Clear location activity, and then select Clear.
Important notes:
- Even with Windows location settings turned off, some third-party apps and services can still estimate location using Bluetooth, IP address, or cellular data.
- Desktop apps do not support per-app control over precise location the same way Microsoft Store apps do.
- If ads or websites still show another state, they may be using IP-based location rather than the Windows default location.
A wrong location by itself does not indicate account compromise.
