Recover my MS surface laptop studio
Xiao Wen 0 Reputation points
2026-09-10T04:43:14.7133333+00:00
I have a MS Surface Laptop Studio and it runs all kind of login issues these day.
After working with MS support, it ended up starting up with "Boot error: Couldn't find a bootable operating system. Check the boot configuration to try to fix this: blue window, then Surface UEFI window.
And I followed the instructions of the support person and created a recovery drive; it just won't start recovery.
Can someone please help?
Thank you
Windows for home | Windows 11 | Recovery and backup
    2026-09-10T04:43:28.4133333+00:00
    For a Surface Laptop Studio, use the Surface-specific recovery image and then check the UEFI settings that control USB boot.
    1. On a working Windows PC, go to the Surface Recovery Image Download page.
      • Select the exact Surface Laptop Studio model.
      • Download the recovery image .zip file.
      • If multiple images are offered, select the most recent version.
    2. Recreate the USB recovery drive carefully.
      • Use a USB drive with enough space. 32 GB is large enough for any recovery image.
      • The drive must be FAT32 and USB 3.0 or higher is recommended.
      • Warning: creating the recovery drive erases everything on the USB drive.
      • In Windows, insert the USB drive.
      • Open Start, type recovery drive, and select Create a recovery drive.
      • Approve User Account Control.
      • Clear Back up system files to the recovery drive.
      • Select the USB drive, then Next > Create.
      • When finished, open the downloaded recovery image .zip and copy all files to the USB drive.
      • Choose to replace the files in the destination.
      • Safely eject the USB drive.
    3. If the Surface still will not start recovery from that USB, check these UEFI items:
      • Ensure boot from USB is enabled in Surface UEFI.
      • Configure the boot order so the USB drive is first.
      • Check Secure Boot configuration.
    4. If the USB recovery drive still does not work, newer Surface devices require updated recovery images that use a 2023 Secure Boot certificate. Download a fresh recovery image from Microsoft and try again.
    5. Important result of recovery:
      • A recovery drive can reset the Surface to factory condition.
      • It reinstalls Windows, deletes personal files, resets settings, and removes installed apps.
    6. If recovery still does not start after recreating the USB and checking USB boot, boot order, and Secure Boot, use Surface support options from the Surface app or Get Help.
  2. Kai-H 26,135 Reputation points Microsoft External Staff Moderator
    2026-09-10T11:15:58.8666667+00:00
    Hi, Xiao Wen
    This error means the Surface cannot find Windows on its internal drive. Since the recovery USB is not starting, the issue may be with USB detection, damaged Windows boot files, or the internal SSD itself.
    Besides the solutions provided by the Q&A Assist, here are some suggestions you can try:
    Disconnect every accessory except the charger and recovery USB, including docks, adapters, external drives, keyboards, and mice. Surface may try to start from another connected USB device. Then power it off and try the Volume Down + Power startup again. Boot Surface from a USB device
    Perform a forced restart by holding the Power button for about 20 seconds, releasing it only when the Windows logo appears. Surface turns on and shows “Couldn't find a bootable operating system”
    As an alternative, create standard Windows 11 installation media on another PC. If it starts, choose Repair your computer first rather than Install now. Reinstalling Windows is the final option and may erase the drive.
    If Windows Setup cannot detect the internal drive, stop there and arrange a hardware inspection or service order, since the SSD may need professional attention.
    Thank you for your patience in reading, I hope this information has been helpful to you.
    If the answer is helpful, please click "Yes" and kindly upvote it. If you have extra questions about this answer, please click "Comment."
