I'm having problems adding guest to my new Group in outlook
John Little 0 Reputation points
2026-09-09T21:26:54.9566667+00:00
i can only add 9 guest and need to add more
  1. Kai-L 19,050 Reputation points Microsoft External Staff Moderator
    2026-09-09T21:41:33.2266667+00:00
    Dear John,
    As a forum moderator, I am not able to access your account or delve into the backend systems to diagnose and fix this for you. My role here is limited to general guidance you can apply from your side. To narrow it down, could you clarify a few things?
    1. What happens when you try to add the tenth guest, and is there an error message?
    2. Are you the group owner?
    3. Do the additional guests already exist in your organization as guest users?
    4. Can you add the same guests to another Microsoft 365 Group?
    5. Does it behave the same way in Outlook on the web?
    Once I have a clearer picture, I will do my best to point you in the right direction. Looking forward to your reply.
