Double Billing
Kevin H 0 Reputation points
2026-09-09T21:03:02.01+00:00
My billing cycle bills on the 18th of the month; there has been an attempt to bill on the 4th of the month. My account shows no invoice outstanding or due for the 4th. My account/billing info is either being fraudulently used, or I have a forgotten about account that has stuffily started billing to my card (which I don't think is the case). How can we explore billings to my card to determine and clarify the root cause of the billing attempt on the 4th/Sept/26?
Microsoft 365 and Office | Subscription, account, billing | Other | Other
    2026-09-09T21:03:22.09+00:00
    Use this path to determine whether the Sept 4 billing attempt is a real Microsoft charge, a retry of an earlier failed payment, another Microsoft account using the same card, or card misuse:
    1. Review Microsoft order history. Sign in and check your order history for charges of the same amount that appear close together. Microsoft notes that what looks like a duplicate charge can be a retried payment after insufficient funds, where a late payment and the next on-time payment appear close together.
    2. Check whether recurring billing or another purchase explains it. Common causes of unexpected Microsoft charges include:
      • a subscription with recurring billing enabled
      • a previously declined charge being charged again
      • a pre-order or split order shipping
      • an in-app purchase
      • a purchase by someone known to the cardholder, such as a family member
    3. Use Payment options and select Investigate. If the Sept 4 charge does not appear in the current account’s order history, go to Microsoft account Payment options / Manage your payments and select Investigate. This is the Microsoft-supported way to search for other accounts using the same card and investigate an unrecognized charge.
    4. Compare the last few months, not just one billing date. Microsoft specifically advises checking the last few months of order history and bank statements. If payments appear close together, verify whether the total number of successful charges over the period actually matches the subscription term rather than assuming a duplicate bill.
    5. If the card may be compromised, contact the bank or payment provider immediately. If the charge cannot be matched to any Microsoft account and there is concern that payment information was acquired by someone else, contact the bank or payment provider to prevent more charges. Microsoft’s guidance is to report the card as stolen or compromised rather than only disputing the charge, because disputing alone does not prevent additional fraudulent charges.
    6. If more help is needed, contact Microsoft Support. Use Contact Microsoft Support, enter the problem, select Get Help, and then Contact Support.
    If this is an Azure billing scenario instead of a personal Microsoft account subscription, create a billing support request in the Azure portal.
  2. EmilyS726 264.9K Reputation points Independent Advisor
    2026-09-09T21:40:40.3833333+00:00
    This is a public forum, so for your privacy and security, we can’t help with billing issues here. Also, no one in this forum has access to your account or payment information.
    To get help, open the "Get Help" app on your computer (just search for it in the Start menu). or go to https://support.microsoft.com/contactus, Type "Billing" and press Enter. On the next screen, click "Contact support" at the bottom of the page, then choose "Microsoft 365" > "Manage my subscription". You’ll then see the option to chat with a Microsoft support agent who has access to your account to help review the issue.
    You can reference this detail step by step instruction with screenshots I posted in this thread: https://learn.microsoft.com/en-us/answers/c/2714817
