A Microsoft file hosting and synchronization service.
Yes — the current setup is using the old account in OneDrive on that laptop, which is why the original OneDrive still appears in the taskbar and remains accessible there.
For Microsoft 365 Family, each person should use their own Microsoft account. If multiple people use the same sign-in, OneDrive content appears shared because it is the same OneDrive account. A Family subscription is meant to be shared with up to five Microsoft accounts, not by reusing one login across devices.
To separate the Family member’s OneDrive on the laptop:
- On the laptop, open the OneDrive cloud icon in the taskbar.
- Open Help & Settings > Settings.
- Go to the Account tab.
- Remove the old account from OneDrive on that device. If needed, use Unlink this PC for the original account.
- In the same Account tab, select Add an account.
- Sign in with the Family member’s Microsoft account.
Expected result: the laptop will sync the Family member’s OneDrive in File Explorer/taskbar, instead of continuing to show the original personal OneDrive account.
Important limits and behavior:
- On a Windows PC, OneDrive supports multiple work or school accounts, but only one personal OneDrive account.
- If the laptop is still signed in with the original personal OneDrive account, that is the one being shown in the taskbar.
- To keep files private and separated, each family member should sign in to Office and OneDrive with their own Microsoft account that has the Family benefit.
A full uninstall of Microsoft 365 is not the required first step based on the documented setup flow. The supported path is to remove or unlink the old OneDrive account from that PC and then add the Family member account in OneDrive settings.
If the goal is stronger separation on a shared laptop, using separate Windows user accounts is the cleanest setup so each person’s OneDrive stays isolated in their own Windows session.
