Resolved the issue for now by uninstalling
2026-09 Security Update (KB5124008) (26200.9445)
Did this all three computers that had the issue and it resolved the issue on all three.
Ran Windows Update on two sepearate Windows 11 computers that were all up to date as of Saturday morning - broke File History
Today I ran File History on 2 computers - both ran correctly. Then ran Windows Update and File History on both are now broken. File History panel pops up but will not run - says to connect a drive. (drive was connected and verified that I could read and write to it)
Reached out to support who logged on to one of the computers, but troubleshooting did not provide an answer. Later I connected a drive and configured File History on a 3rd computer - it was working. Then I ran Windows Update and it broke it.
Updated the case number and was told now by two seperate techs that it seems to be an issue with one of the updates and was passing it on to level 2 with the detailed testing notes I provided.
The three updates that were installed were
2026-09 .NET Framework Security Update (KB5126052)
Windows Malicious Software Removal Tool x64 - v5.145 (KB890830)
Working before the update - not working after the update
just letting others know in case they are running into the same issue.
Hi All,
As of today 26200 is up to .9539.
Hope it fixes the issue for all of you.
Hi Bob,
Apparently it's a gradual rollout
under Windows Update, so if you don't
see it right away give it a few days.
