Microsoft 365 features that help users manage their subscriptions, account settings, and billing information.
For a full tenant lockout with no working Global Administrator, the supported path is Microsoft 365 support and identity verification. There is no separate self-service escalation that bypasses tenant recovery.
Based on the described state:
- Try the standard recovery entry points first:
- Go to the admin portal.
- Try any previously used admin sign-in, including the original
onmicrosoft.comadmin account. - If prompted to request admin access, follow that flow.
- If sign-in and recovery prompts fail, open a support request through Microsoft 365 support:
- Go to the Microsoft 365 support page.
- Select I can't sign in or access my tenant.
- Be prepared to verify organizational ownership through items such as:
- official business documentation
- domain ownership
- publicly listed company registration data
- Because the tenant was originally provisioned through GoDaddy, confirm whether the custom domain is still tied to a GoDaddy-provisioned Microsoft 365 tenant state:
- If sign-in is redirected or blocked because of a GoDaddy-managed connection, contact GoDaddy and request release of the custom domain from the Microsoft 365 tenant.
- This can temporarily disrupt email service, so confirm impact before proceeding.
- After release, sign in with the default
NETORG...onmicrosoft.comadmin account if applicable, and use Forgot my password if the password is unknown.
- If a partner previously managed the tenant and still has an active GDAP relationship with the required roles, the partner can help with password reset or elevation. If there is no partner with the required GDAP access and no other Global Administrator exists, Microsoft support is the required path.
- For a locked-out tenant owned by the organization, Microsoft support can route the case for credential reset or ownership claim after verification. The documented support path states that if locked out of a tenant, a support ticket must be opened.
Supported answers to the specific questions:
- For escalation beyond normal self-service: the documented path is still Microsoft 365 support with identity verification. Microsoft for Nonprofits and similar program teams cannot bypass identity verification or directly restore tenant access.
- For the “working email address” issue: the documented process focuses on identity and ownership verification, not on requiring access to the affected tenant’s email. Domain ownership and business documentation are explicitly listed as verification methods.
- For the GoDaddy history: the documented GoDaddy issue pattern is domain binding, redirected login, or blocked admin access. The provided material does not document a confirmed pattern of all user objects disappearing after migration to direct Microsoft management, so no supported conclusion can be drawn on that point.
