Updating Billing Info
Fred Behar 0 Reputation points
2026-09-07T14:36:39.6166667+00:00
I need to make a Skype call. I am asked to update my billing info in order to activate my Skype credit. Tried many times via Edge and private browsing to update my billing info address but each time get error message.
Microsoft Teams | Microsoft Teams Free | Calls
  1. Ruwim.B 6,900 Reputation points Volunteer Moderator
    2026-09-07T14:40:45.98+00:00
  2. AI answer
    2026-09-07T14:36:55.0933333+00:00
    If Skype Credit cannot be activated because the billing address update fails, use this sequence:
    1. Open account.live.com and go to Your info.
    2. Verify Language is selected and correct. A missing or invalid language/region setting can block billing address updates.
    3. Verify Country/Region is correct.
    4. Save any profile changes.
    5. Try updating the billing address again.
    6. If it still fails, use an InPrivate/Incognito browser window and try again.
    7. If needed, temporarily change Country/Region to another country, save, then change it back to the correct country and re-enter the billing address.
    8. After the billing info is accepted, try reactivating Skype Credit and then open the Skype Dial Pad again.
    Relevant checks for calling:
    • Make sure the same personal Microsoft/Skype account is signed in that holds the Skype Credit.
    • If the account shows Account blocked, paid services may be suspended temporarily because of payment issues, and billing address information may be required before Skype Dial Pad can be used.
    • Active subscriptions or Skype Credit can be checked by signing in to https://calling.web.skype.com/.
