Keys on keybord do not work, exmple the letter Q & A The shift key & the Control key do not work
Mark Richardson 0 Reputation points
2026-09-03T20:09:43.4233333+00:00
My laptop keyboard is not fully functional. Keys like the letter A – Q- 8 – Control do not work. I am currently typing by using the screen keyboard. How do I fix this.
[Moderator Note: Personal Info Removed]
<moderator: PII removed>
  1. Clary-N 15,735 Reputation points Microsoft External Staff Moderator
    2026-09-04T00:41:52.78+00:00
    Please note that our forum is a public platform, and we will modify your question to hide your personal information in the description. Kindly ensure that you hide any personal or organizational information the next time you post an error or other details to protect personal data.
    Hi Mark Richardson,
    Thank you for reaching out.
    Since several keys, including A, Q, 8, Shift and Ctrl are not responding, I recommend trying the following:
    1. Open Settings > Accessibility > Keyboard, then turn off Filter Keys, Sticky Keys and Toggle Keys.
    2. Open Device Manager, expand Keyboards, uninstall the keyboard device and restart the laptop so Windows can reinstall it.
    3. Test with an external USB keyboard. If it works normally, the issue may be limited to the built-in keyboard.
    4. Test the affected keys in the laptop’s BIOS/UEFI. If they also do not work there, this would suggest a hardware issue that may require inspection or repair.
    Could you share the laptop’s make and model, whether this started after an update, spill or physical impact and whether the affected keys work in BIOS/UEFI?
    I hope this helps. Please let me know the results, and I’ll be happy to assist further.
    If you have extra questions about this answer, please click "Comment".
