camera settings
James Douglas 0 Reputation points
2026-09-03T12:36:02.24+00:00
Can't get camera to work on teams. says my system is blocking camera access. i have to give permission for all apps. i have done this. no change.
Microsoft Teams | Microsoft Teams for business | Meetings and calls | Audio and video
    2026-09-03T12:36:18.6633333+00:00
    If Windows says the system is blocking camera access and the general app permission is already on, check the Windows camera settings that affect desktop apps. Microsoft Teams is a desktop app.
    1. Open Start > Settings > Privacy & security > Camera.
    2. Make sure Camera access is On.
    3. Make sure Let apps access your camera is On.
    4. Make sure Let desktop apps access your camera is On.
      • Teams needs this setting.
      • Desktop apps cannot be allowed one by one in this section.
    5. If Microsoft Teams (work or school) appears in the app list, turn it off and back on.
    6. Close all apps and restart the device.
    If it still fails, check whether the camera is blocked outside Teams:
    1. Open the built-in Camera app.
      • If the Camera app also shows a blocked, gray, or locked image, the issue is in Windows or the device, not Teams.
    2. Check for a physical camera shutter, privacy slider, or keyboard camera key on the laptop. Some devices can block the camera at the hardware level.
    If the problem happens only in Teams on the web, also allow the camera in the browser:
    • Edge: Settings > Cookies and site permissions > Camera > turn on Ask before accessing (recommended).
    • Chrome: Settings > Privacy and security > Site settings > Camera > select the correct camera and set Sites can ask to use your camera.
    • Firefox: Settings > Privacy & Security > Permissions > Camera > Settings and allow the Teams site.
    • Then refresh Teams and rejoin the meeting.
    If the camera works intermittently or is sometimes not detected, try:
    1. Open Settings in Windows.
    2. Go to the camera settings for the device.
    3. Open Advanced camera options.
    4. Enable Basic camera driver mode.
    5. Restart Teams and test again.
    If Camera access cannot be changed in Windows settings, an administrator on the device must change it.
  2. Alina Le 5,000 Reputation points Independent Advisor
    2026-09-03T13:42:02.6933333+00:00
    Hello James,
    Might I confirm you are using the Teams desktop app on Windows?
    If so, could you please try the following troubleshooting steps first:
    1/ Check if the camera works in Windows
    • Open the "Camera" app and verify whether the camera works there.
    • If the Camera app cannot access the camera either, the issue is likely related to Windows settings, drivers, or the device itself rather than Teams.
    User's image User's image
    2/ Verify Windows camera permissions
    • Go to Settings > Privacy & Security > Camera.
    • Make sure the following options are turned "On":
      • Camera access
      • Let apps access your camera
      • Let desktop apps access your camera
    3/ Check the camera settings in Teams
    • Open Teams > Settings > Devices.
    • Under Camera, select the correct camera and check whether a preview is displayed.
    4/ Close any other applications that may be using the camera
    • Completely close applications such as Zoom, Skype, Discord, OBS, or any browser tabs that may be accessing the camera.
    • Restart Teams and test again.
    5/ Check Device Manager
    • Press "Windows + X" and open "Device Manager".
    • Expand "Cameras".
    • Ensure the camera is enabled and does not show any warning icons.
    User's image User's image User's image
    I hope I've been able to help in some way. Please keep me posted.
  3. EmilyS_726 27,560 Reputation points Volunteer Moderator
    2026-09-04T15:43:13.9533333+00:00
    Hi James, there is a chance it is physically blocked.
    Most camera issues can be due to a physical privacy cover covering the lens. Make sure that's not the case.
    Otherwise there is usually a physical button/key/switch you can use to turn the camera on or off. For example, most Lenovo uses F8 or Fn+F8, or a switch above the lens, HP has a camera key or a button on the side of the laptop, MSI uses F6 or Fn+F6, etc.
    If you are not sure, tell me the brand and model of your computer.
