Managing sound and video settings during Teams meetings and calls for optimal communication
Hi Jean,
Based on the information you've shared, the AI response already outlines the most common troubleshooting steps for this type of audio device issue in Microsoft Teams. I recommend trying those suggestions first, as they often resolve problems related to incorrect speaker or microphone selection.
If the issue persists, please also try the following:
- Open Windows Settings and navigate to System > Sound.
- Under Choose where to play sound, select the speaker or headset you want to use.
- Confirm that the device is not muted and that the volume is turned up.
- If you are using a wired device, disconnect and reconnect it. If it is a Bluetooth device, make sure it is charged and not currently connected to another device.
- Fully close Microsoft Teams, reopen it, and then review Settings > Devices to verify that the correct speaker and microphone are selected.
As a temporary workaround for urgent meetings, you can select Phone audio from the Teams pre-join screen. This allows you to use your phone for both microphone and speaker audio while continuing to participate in the meeting from your computer.
For additional guidance, please refer to Microsoft's documentation : Manage audio settings in Microsoft Teams meetings | Microsoft Support
If your speaker works normally in other Windows applications but still does not appear or produce sound in Teams after completing the steps above, I recommend reaching out to your IT administrator. They can verify the device configuration, audio drivers, and any organizational policies that may affect available audio devices in Teams.
Should the issue remain unresolved, your IT administrator can also engage Microsoft Support for further investigation. Guidance on how to create a support request can be found here: Get support - Microsoft 365 admin.
If you are unsure who your IT administrator is, you can refer to this official Microsoft guide for assistance: How do I find my Microsoft 365 admin? - Microsoft Support
I hope this information helps. Please let me know the results after trying these steps, and I will be happy to assist further if needed.
Warm regards.
If the answer is helpful, please click "Yes". If you have extra questions about this answer, please click "Comment".
