Code problem
howard gray 0 Reputation points
2026-08-31T12:04:01.86+00:00
I'm setting up a new mobile phone and the verification code Microsoft sends me I key in CORRECTLY only to get "wrong code"error?
Microsoft Security | Microsoft Authenticator
    2026-08-31T12:04:17.61+00:00
    If the code is entered correctly but Microsoft says it is wrong on a new phone, the most relevant fixes are:
    1. Verify that the code is being sent to the expected method.
      • Check that the phone number or email shown is the correct security info.
      • Go to the Security page, select Update info, and choose a method that is known to work.
    2. If the old and new verification addresses are both Microsoft accounts, use private browsing.
      • Sign in to the account requesting the code in one InPrivate/private window.
      • Open a second InPrivate/private window and sign in to the alternate Microsoft email account that receives the code.
      • Copy the code from that message back into the first window.
      • This avoids being signed out of the first account while retrieving the code.
    3. Check for delivery issues that can make a code effectively unusable.
      • Check Junk email for messages from @accountprotection.microsoft.com.
      • If using SMS, make sure the phone does not block texts from unknown numbers, the inbox is not full, and the messaging app is working.
      • VOIP numbers cannot be used for sign-in or verification codes; use a mobile number instead.
    4. Avoid repeated requests.
      • Excessive or repetitive requests can trigger a temporary block and prevent codes from being sent or accepted normally.
      • If many attempts were made, stop retrying for a period and try again later.
    5. If access to the old security method is lost, replace the security info.
      • If at least one existing method still works, sign in to Advanced security options, add a new way to sign in or verify, confirm it, then remove the old method.
      • Do not change all security info at the same time, because the account may be restricted for 30 days.
      • If all security info is lost, at the Verify your identity prompt select I don't have any of these and follow the replacement process. After replacement, there is a 30-day wait before sign-in is allowed.
