Real-time voice or video communication between users on mobile devices or computers
If the speaker is not working during Test Mic and Speaker in Microsoft Teams, use these checks:
- In Teams, go to Settings and more > Settings > Devices.
- Under Audio > Audio settings, make sure the correct device is selected in the Speaker dropdown.
- Select Make a test call and follow the Test Call Bot prompts.
If the speaker device does not appear:
- For a Bluetooth speaker, make sure it is charged and reconnect it.
- For a wired speaker or headset, unplug it and plug it back in.
If the issue happens during a meeting:
- In the meeting window, select the dropdown arrow next to Mic.
- Select More actions > Audio settings.
- Under Speaker, confirm the correct device is selected and unmuted.
In Windows, also verify the speaker is enabled:
- Open Start and search for Sound settings.
- Go to System > Sound.
- Under Choose where to play sound, select the speaker.
- Next to Volume, make sure it is not muted.
- If needed, go to Advanced > More sound settings and re-enable the device.
If using Remote Desktop:
- Open Remote Desktop Connection.
- Select the Local Resources tab.
- Under Remote audio, select Settings….
- Set Remote audio playback to Play on this computer.
- Set Remote audio recording to Record from this computer.
Also make sure Teams and the operating system are up to date.
Note: the test call feature is currently available in English only and is unavailable on Teams for web. A Microsoft Q&A entry also notes that the test option can be unreliable, and that Test call in Settings > Devices is not available with a personal subscription.
