Locked out of my onedrive
Femke Verstuyft 0 Reputation points
2026-08-27T07:53:35.1133333+00:00
I can no longer log in to my email account because there was a “suspicious login attempt.” The options I’m given to log in again are an email address that no longer exists or a phone number that no longer exists. I now have a new email address and a new cell phone number. I also hadn’t set up two-step verification yet, so I can’t use that either. When I try to enter my password, after just one attempt I get a message saying I can’t try again because there have already been too many attempts on that account. I’ve tried several times to fill out a Microsoft Account Reinstatement Form, but my requests keep getting rejected. I don’t know what else I can do.
The fact that I can’t access my email anymore isn’t that big of a deal, because I’ve already created a different email address in the meantime. The only problem is that this old email is still linked to my OneDrive. So I can no longer access the files on my OneDrive. If I understand correctly, these files are locked until my request is approved (but it’s already been rejected 10 times).
Is there any other way to get my files from OneDrive onto my computer? I’m at my wits’ end because these files are extremely important. Thanks in advance for any help you can offer.
Microsoft 365 and Office | OneDrive | Other | Windows
  1. Nathan R 915 Reputation points Independent Advisor
    2026-08-27T08:58:21.9166667+00:00
    Hey there, Femke Verstuyft
    Sorry to read that you are unable to get your OneDrive files because of the too many log-in attempts block that is in place.
    If you no longer have access to the security information on your account, you will need to complete the Microsoft account recovery form here: https://go.microsoft.com/fwlink/?linkid=2288285
    When completing this form, please include as much information as possible. This will allow Microsoft to verify you are the owner of the account. Further information on how to complete this form can be found in this article here: https://support.microsoft.com/en-us/accounts-billing/manage/help-with-the-microsoft-account-recovery-form
    Yes, you are correct with this. Until you are able to get access to your Microsoft account, you won't be able to sign into the OneDrive website to get access to your files.
    However, it is worth noting that if you have downloaded the files onto your PC/device through the OneDrive sync client, you will be able to copy these files to your downloads folder and be able to access them offline. This will only allow you to get files you have recently opened, and will only have changes that were synced to them from a previous successful login on the sync client.
    Please can you have a look at your PC and check if you have any documents that are available.
    If you know your password, but are getting blocked due to login attempts. Please can you wait 8 to 24 hours and try again. It may be worth trying to sign into your account through an InPrivate browsing window to see if this makes a difference.
    Please can you also use the sign-in helper tool which will identify any problems and how to resolve them here: https://aka.ms/sign-in-helper
    Hope this information helps,
    Nathan
