HOW DO I GET MY CANNON TS3355 TO PRINT A COPY OF A DOCUMENT
BARRY TAYLOR 0 Reputation points
2026-08-26T15:48:52.89+00:00
I WANT MY CANNON TS 3355 TO PHOTO COPY A DOCUMENT,ALL IT DOES IS PRINT INFO SHEETS
Windows for business | Windows Client for IT Pros | User experience | Print, fax, and scan
  1. Allan Solomon Mejia 8,000 Reputation points
    2026-08-26T20:44:29.06+00:00
    Hello @BARRY TAYLOR
    You don't need a computer to photocopy a document with the Canon PIXMA TS3355.
    1. Turn the printer on.
    2. Load plain paper into the rear tray.
    3. Lift the scanner cover and place your document face down on the scanner glass, aligned with the positioning mark in the corner.
    4. Close the scanner cover.
    5. Press the Black button for a black-and-white copy or the Color button for a color copy.
    The printer should scan the document and print the copy directly.
    If it's printing printer-information/network sheets instead, make sure you're pressing the Black or Color copy button, rather than the Information/Network button.
    If pressing Black/Color still produces an information sheet, please let us know which button you're pressing and what appears on the printer's LCD, and we can narrow it down.
    Please "Accept the Answer" if this information helped you. This will help us and others in the community.
  2. EmilyS_726 27,560 Reputation points Volunteer Moderator
    2026-08-27T23:06:14.0133333+00:00
    You said "LCD shows 1 sheet and one copy from the tool key".
    For Canon TS3355, the tool/spanner button is THE SETUP button. When you said the above, I believe you pressed the button because you thought the "1" on the LCD means "1 copy"?? That's the problem. When you press SETUP until 1 appears, you actually selected maintenance function 1, which will print nozzle check pattern. Then pressing black or white causes the printer to print a test sheet instead of copying the document. I bet that was what happened.
    I don't think the TS3355 has a document feeder. I don't think there is a copy menu either. This is the instructions I found from Canon: https://ij.manual.canon/ij/webmanual/Manual/All/TS3300%20series/EN/UG/ug-005.html
    What you should do according to the instruction link I shared right above.
    Do NOT press the tool/Setup button
    Put the paper in the rear tray.
    Put the document face down on the scanner glass.
    Close the lid, press black or color directly. That should start copying.
