can you guys pretty please help learn how to connect earplugs or headphones to a samsung windows 7
Tracy Zoe 0 Reputation points
2026-08-25T16:26:19.9766667+00:00
how do you connect earplugs or headphones to a samsung laptop windows 7 beacause when i try to connect the earplugs they connect but the sound doesnt work then when i try so so so so so so so so so so so hard to connect the flippin' headphones to the laptop i dont find the flippin' bluetooth icon so can you please help me cause i really need it
  1. Emma1-N 12,450 Reputation points Microsoft External Staff Moderator
    2026-08-25T23:38:20.44+00:00
    Welcome Tracy Zoe,
    I understand how frustrating it can be when you need your headphones to work.
    Since Windows 7 reached end of support on January 14, 2020, this product is EOS, but you can still try these workaround steps.
    1. Check whether your headphones are wired or Bluetooth
      • If they are wired, plug them fully into the headphone jack and test if sound works
    2. Set the headphones as the default playback device
      • Right-click the speaker icon in the taskbar
      • Select Playback devices
      • If your headphones appear, select them and click Set Default
    3. Check whether Bluetooth is available.
      • Press Windows Key + R.
      • Type devmgmt.msc and press Enter.
      • Look for a category named Bluetooth
      • If Bluetooth is not listed, your laptop may not have a Bluetooth driver installed
    4. Please let me know:
      • Are you using wired earphones or Bluetooth headphones?
      • What is the Samsung laptop model?
      • Do the headphones work on another device, such as a phone?
    If the answer is helpful, please click "Yes". If you have extra questions about this answer, please click "Comment".
