Problem with Whiteboard operation
Walsh Keira 0 Reputation points
2026-08-25T01:08:30.4633333+00:00
I'm having trouble with Whiteboard.
An error pops up, or the application stops working or even when it loads, it gets stuck after a while.
I tried logging in again, uninstalling apps, tried in the browser, but nothing worked.
Microsoft 365 and Office | Install, redeem, activate | For education | Other
  1. Hani-Ng 1,130 Reputation points Independent Advisor
    2026-08-25T01:22:45.54+00:00
    Hi Walsh Keira
    Since you've already tried signing out and back in, reinstalling the application, and using Whiteboard from a web browser, the issue may be related to either the Education tenant configuration or the Whiteboard service itself rather than the local device. Microsoft Whiteboard for Education and Enterprise organizations must be enabled by the administrator at the tenant level. If the service is disabled, users may experience loading issues, errors, or boards that stop responding.
    You can try to:
    • Test Whiteboard using another browser (Edge InPrivate window recommended) and a different network connection if available.
    • Verify whether other users in the same school/organization are experiencing the same problem.
    • Ask the Microsoft 365 Education administrator to confirm that:
      • Whiteboard is enabled for the organization.
      • Whiteboard Services is enabled in Microsoft Entra ID.
      • The tenant meets the required Whiteboard configuration requirements
    If the issue persists, to better understand your situation, could you please share some information:
    • The exact error message or a screenshot.
    • Whether the issue occurs on the desktop app, web version, or both.
    • Whether the problem affects only your account or multiple users in the organization.
    I hope this helps and look forward to your response.
    Note: Please follow the steps in the forum documentation to enable e-mail notifications if you want to receive the related email notification for this thread.
