How to fix “The credential is invalid.”
WING KIU KAN 0 Reputation points
2026-08-22T18:26:05.0333333+00:00
Troubleshooting details
If you contact your administrator, send this info to them.
Copy info to clipboard
Correlation Id: [Moderator note: personal identifiable Information removed]
Timestamp: 2026-08-22T18:06:18.000Z
DPTI: [Moderator note: personal identifiable Information removed]
Message: The credential is invalid.
Tag: 488do
Code: -50004
I could not log in to Teams and Outlook (all MS apps), due to errors keep popping up on MS Authenticator.
I am using Apple Device, please provide relevant steps to resolve this issue.
Microsoft Teams | Microsoft Teams for business | Sign up and Sign in | Sign in
  1. Killian N 3,820 Reputation points Independent Advisor
    2026-08-22T18:52:30.68+00:00
    Since this is a work or school account and the error code: -50004 ("The credential is invalid") is often related to an issue with the account's authentication credentials or MFA registration. The recommended next step is to contact your IT administrator and ask them to review and, if necessary, reset your Microsoft Authenticator/MFA registration for the account.
    Your IT administrator has the necessary permissions to investigate the sign-in logs and resolve account-related authentication issues.
    You can specifically ask whether they can
    • Reset your MFA settings
    • Require MFA re-registration
    • Remove your existing Authenticator registration so you can set it up again
    You may also want to share the following Microsoft article with them: Manage authentication methods for Microsoft Entra multifactor authentication - Microsoft Entra ID |…
    If you are unsure who your IT administrator is, you can refer to this official Microsoft guide for assistance: How do I find my Microsoft 365 admin? - Microsoft Support
    Once your IT administrator resets your MFA registration and review your credential, you should be able to sign in again and go through the Microsoft Authenticator setup process from the beginning, including scanning a new QR code on your device.
    I hope this points you in the right direction.
    Best regards,
    If the answer is helpful, please click "Yes" and kindly upvote it. If you have extra questions about this answer, please click "Comment".
    Note: Please follow the steps in forum documentation to enable e-mail notifications if you want to receive the related email notification for this thread.
  2. Shiv Om Tripathi 0 Reputation points
    2026-08-22T18:49:34.77+00:00
    Try these steps in this order on your iPhone:
    1. Update everything first
    • Open App Store → Microsoft Authenticator → Update
    Also update Teams, Outlook, and Microsoft Company Portal if installed.
    Go to Settings → General → Software Update and install any available iOS update.
    Microsoft specifically recommends using the latest Authenticator version and keeping the device/security apps updated. ([Microsoft Support](https://support.microsoft.com/en-us/authenticator/troubleshoot-problems-with-microsoft-authenticator?utm_source=chatgpt.com"Troubleshoot problems with Microsoft Authenticator | Microsoft Support"))
    2. Check iPhone date/time
    Go to:
    Settings → General → Date & Time → Set Automatically → ON
    An incorrect device clock can cause Authenticator authentication problems. ([Microsoft Support](https://support.microsoft.com/en-us/authenticator/troubleshoot-problems-with-microsoft-authenticator?utm_source=chatgpt.com"Troubleshoot problems with Microsoft Authenticator | Microsoft Support"))
    3. Check Authenticator notifications
    Go to:
    Settings → Notifications → Authenticator
    Allow Notifications → ON
    Lock Screen → ON
    Banners → ON
    Sounds → ON
    Also make sure Focus / Do Not Disturb isn't blocking the notification. ([Microsoft Support](https://support.microsoft.com/en-us/authenticator/troubleshoot-problems-with-microsoft-authenticator?utm_source=chatgpt.com"Troubleshoot problems with Microsoft Authenticator | Microsoft Support"))
    4. Change your network
    Try:
    Wi-Fi → Mobile Data
    or Mobile Data → Wi-Fi
    If you're using a VPN, turn it off temporarily. Microsoft specifically recommends testing another network and disconnecting VPNs when troubleshooting Authenticator. ([Microsoft Support](https://support.microsoft.com/en-us/authenticator/troubleshoot-problems-with-microsoft-authenticator?utm_source=chatgpt.com"Troubleshoot problems with Microsoft Authenticator | Microsoft Support"))
    5. Open Authenticator directly
    Don't start from Teams.
    Open Microsoft Authenticator → find your college/work account.
    If the account tile says something like:
    Action required
    Sign in to restore
    Inactive
    Credential unavailable
    tap the account and complete the sign-in/recovery process.
    For work/school accounts, restoring Authenticator generally restores the account name, but you may have to authenticate again. ([Microsoft Support](https://support.microsoft.com/en-US/authenticator/restore-account-credentials-from-microsoft-authenticator?utm_source=chatgpt.com"Restore account credentials from Microsoft Authenticator | Microsoft Support"))
    6. Try signing in through the browser
    On Safari, try your organization's Microsoft sign-in page and sign in with your college/work Microsoft account.
    When Microsoft asks for verification, choose:
    Other ways to sign in
    If available, try:
    Authenticator
    SMS
    Phone call
    Security code
    Microsoft supports using another verification method when Authenticator isn't working. ([Microsoft Support](https://support.microsoft.com/en-US/authenticator/sign-in-using-microsoft-authenticator?utm_source=chatgpt.com"Sign in using Microsoft Authenticator | Microsoft Support"))
    . Don't delete Authenticator yet
    This is important.
    Do NOT immediately uninstall Authenticator or remove your college account from it.
    If Authenticator is your only MFA method, deleting the registration can leave you unable to sign back in. Microsoft notes that work/school accounts may need to be registered again after restoration. ([Microsoft Support](https://support.microsoft.com/en-US/authenticator/restore-account-credentials-from-microsoft-authenticator?utm_source=chatgpt.com"Restore account credentials from Microsoft Authenticator | Microsoft Support"))
    7. If it still says “The credential is invalid”
    At this point, because multiple Microsoft apps are failing, your college/company Microsoft administrator probably needs to check your Microsoft Entra ID sign-in logs and authentication registration.
    Give them:
    Error: The credential is invalid
    Code: -50004
    Tag: 488do
    Timestamp: 2026-08-22 18:06:18 UTC
    Correlation ID: the one shown on your screen
    Microsoft's Entra troubleshooting documentation specifically uses the sign-in logs, failure reason, additional details, and correlation information to diagnose authentication failures. ([Microsoft Learn](https://learn.microsoft.com/en-us/entra/identity/monitoring-health/howto-troubleshoot-sign-in-errors?utm_source=chatgpt.com"How to troubleshoot sign-in errors - Microsoft Entra ID | Microsoft Learn"))
    Ask the administrator to check whether your Authenticator/MFA registration or device registration needs to be reset/re-registered.
    Also, inside Authenticator, Microsoft recommends using Send Feedback to submit diagnostic logs if the problem persists. ([Microsoft Support](https://support.microsoft.com/en-us/authenticator/troubleshoot-problems-with-microsoft-authenticator?utm_source=chatgpt.com"Troubleshoot problems with Microsoft Authenticator | Microsoft Support"))
    Most important: If this is your college Microsoft account, don't waste time reinstalling Teams and Outlook repeatedly. If Authenticator itself can't validate the credential, reinstalling Teams/Outlook won't fix the underlying authentication problem. The admin may need to reset your MFA registration.Yes. Since Teams, Outlook, and other Microsoft apps are all failing, while Authenticator is also throwing errors, this is more likely an account/Authenticator registration or Microsoft Entra authentication issue than a Teams/Outlook app problem. The key error is “The credential is invalid” (-50004).
    Go to:
    Go to:
    Lock Screen → ON
    Banners → ON
    Sounds → ON
    Try:
    Wi-Fi → Mobile Data
    Action required
    Sign in to restore
    Inactive
    If available, try:
    Authenticator
    SMS
    Phone call
    Security code
    ⚠️ Don't delete Authenticator yet
    This is important.
    Give them:
    Code: -50004
    Tag: 488do
