Teams Test Mic and Speaker Not Working — Known Issue?
Mari A 45 Reputation points
2026-08-22T13:27:49.8766667+00:00
Is anyone else having problems with the Test mic and speaker function in the Microsoft Teams desktop app?
I’m using a headset and it works perfectly with YouTube and other audio, but the Teams test isn’t working. I also tried a different pair of earphones and had exactly the same issue.
I’m wondering if this is a temporary Teams bug or a known issue affecting other users, or if it’s just something on my side. I have an actual Teams meeting coming up, so I’m a little concerned, although I’m hoping the audio will work normally during the meeting.
Has anyone else experienced this recently?
Microsoft Teams | Microsoft Teams Free | Calls
Ruwim.B 6,900 Reputation points Volunteer Moderator
2026-08-23T07:10:43.31+00:00
Are you using this "Test mic and speaker" option in the meeting window?
I have tested this feature several times and must conclude that this test option is not reliable. Speaker test was working, but Microphone test was working sporadically only.
Unfortunately, the "Test call" option in Settings -> Devices is not available when using Teams with a personal subscription. This option is only available with a business subscription.
Mark Glasgow 80 Reputation points
2026-09-02T09:05:41.35+00:00
Yep can confirm the same bug on the latest version of Teams (26213.1006.5011.1671) on Mac M1 Silicon running Tahoe
Test mic worked fine, test sound doesn't work with built-in speakers or headphones - no audio is ever played.
Was able to confirm it was actually working by signing in on my phone and joining the same meeting
4 additional answers
  1. Don Grassmann 0 Reputation points
    2026-09-08T23:23:39.32+00:00
    I can confirm the same issue on two different Win 11 laptops, one running Teams 26213.1006.5014.9784 and the other running 26225.1806.5074.1452. All sounds play normally from all other apps regardless of speaker choice, but Teams test files do not play. All selectors set correctly in Teams app and Windows settings. Sounds do seem to work normally during Teams meetings. Seems like corruption of Teams test sound file or something like that.
  2. Mari A 45 Reputation points
    2026-08-31T11:22:35.9933333+00:00
    I just wanted to add that I had a Teams conference call last week, and both my microphone and speakers worked perfectly during the actual call, even though neither test worked beforehand.
    Hopefully this helps a bit. It might be worth having a backup option, such as joining the meeting by phone, just in case the audio doesn't work during the actual meeting.
  3. Aymeric-B 29,590 Reputation points Independent Advisor
    2026-08-22T14:22:38.2633333+00:00
    Hello !
    The AI answer is correct : there's no known bug about Teams' test call feature.
    Just to clarify : which version of Microsoft Teams are you using currently ? Is it the personal version (with a personal Microsoft account) or a business/school account (provided by your workplace) ?
    The "test call" feature does not exist yet in the free version of Teams.
    If you're using a Windows PC, make sure you've selected the correct headset in the Teams settings panel, and not a software proxy like Intel Smart Sound. If you're using a Mac, check in the System Settings if you're not blocking Teams from playing/capturing sound.
    Please let me know if you have any other question !
