speaker sound problem
Adam Ibrahim Muhammad 0 Reputation points
2026-08-21T21:04:13.1133333+00:00
i don't hear sound from my laptop speakers, please.
    2026-08-21T21:04:32.0466667+00:00
    Try these Windows 11 steps in order:
    1. Check the selected output device
      • Select Start > Settings > System > Sound.
      • Under Output, make sure the laptop speakers are selected.
      • Make sure volume is turned up and not muted.
    2. Check the taskbar speaker selection
      • Select the Speakers icon on the taskbar.
      • Open the list of audio devices and confirm sound is going to the laptop speakers, not headphones, HDMI, or another device.
    3. Check the speaker connection state
      • If headphones were recently used, unplug them.
      • Some laptops stop speaker output while headphones are connected.
    4. Turn off audio enhancements
      • Go to Start > Settings > System > Sound.
      • In Output, select the speaker device.
      • Under Advanced settings, set Audio enhancements to Off.
    5. Run the audio troubleshooter
      • Go to Start > Settings > System > Troubleshoot > Other troubleshooters.
      • In the Audio section, select Run.
    6. Check whether the audio device is disabled
      • Open Device Manager.
      • Expand Sound, video and game controllers.
      • If the audio device appears, right-click it and select Enable device if that option is available.
      • If it does not appear, select View > Show hidden devices, then Action > Scan for hardware changes.
    7. Update or reinstall the audio driver
      • In Device Manager, expand Sound, video and game controllers.
      • Right-click the audio device and select Update driver.
      • If needed, install the latest audio driver from the laptop manufacturer’s support site and restart the PC.
    8. Restart the PC
      • Use Start > Power > Restart.
      • A restart can reload audio services and drivers.
    If the speakers still do not appear in Sound settings or Windows shows “No audio output device is installed”, that usually points to a missing, outdated, disabled, or corrupted audio driver.
