driver 10.0.26100.8972 not recognised by pc
James Stead 0 Reputation points
2026-08-20T19:23:53.99+00:00
this i believe is a bluetooth driver and it says it is updated just not working and i dont know how to fix it
    2026-08-20T19:24:09.3233333+00:00
    If the Bluetooth driver shows as updated but still is not working, use this order:
    1. Update it again in Device Manager
      • Select Start, type Device Manager, and open it.
      • Expand Bluetooth.
      • Right-click the Bluetooth adapter.
      • Select Update driver > Search automatically for drivers.
      • Restart the PC after it finishes.
    2. Check Windows Update
      • Go to Start > Settings > Windows Update.
      • Select Check for updates.
      • Install any available updates and restart.
    3. Reinstall the Bluetooth driver
      • Open Device Manager.
      • Expand Bluetooth.
      • Right-click the Bluetooth adapter and select Uninstall device.
      • Restart the PC.
      • Windows should automatically reinstall the Bluetooth driver.
    4. Roll back the driver if Bluetooth stopped working after a recent driver or Windows update
      • In Device Manager, expand Bluetooth.
      • Right-click the Bluetooth adapter > Properties.
      • Open the Driver tab.
      • Select Roll Back Driver if that option is available.
    5. Install the latest driver from the PC manufacturer
      • Go to the PC manufacturer’s support website.
      • Search by the PC model number.
      • Download and install the latest Bluetooth driver for Windows 11.
      • Restart the PC.
    If the driver is installed but Bluetooth audio is the problem, also verify the Bluetooth device is selected under Start > Settings > System > Sound > Choose your output device.
