Yes, it is reasonable to proceed with USB installation media to reach Windows Recovery Environment and try repair options. If the PC will not start normally, installation media can be used to boot into Windows RE by starting from the USB, going through the initial setup screen, and selecting Repair my PC instead of installing Windows.
Before any recovery or reinstall step, back up important data if possible. Recovery actions such as Reset or reinstall can cause data loss. If recovery options are not working, creating installation media on another working PC and using it to access repair options is the supported path.
A practical order is:
- Back up important files first if they are accessible. Some recovery methods may remove files, apps, and settings.
- Boot from the USB created with Media Creation Tool.
- On the Windows Setup screen, select Next and then Repair my PC to enter Windows Recovery Environment.
- In Windows RE, try non-destructive options first, such as Startup Repair or System Restore if available.
- If those do not work, use reinstall only after confirming backups are complete.
If there is no usable recovery drive or installation media already available, create installation media on another working PC and use that USB to boot the nonworking PC.
