Personal Vault not showing up in my Onedrive folder.
RJ 20 Reputation points
2026-08-19T16:06:31.83+00:00
I have a "Personal Vault.Ink" file but no Personal Vault folder.
SD - IA 178.9K Reputation points Independent Advisor
2026-08-21T07:17:40.9233333+00:00
Click the Cloud icon > Settings > Unlock Personal Vault.
I hope this information helps. If you have any more questions, don't hesitate to reach out.
Otherwise, if your problem is resolved, please take a moment to close the question to help others. Wishing you good luck!
4 additional answers
    2026-08-19T16:06:45.29+00:00
    Personal Vault.lnk is a shortcut, not the actual vault folder. That is expected behavior on Windows.
    Personal Vault appears in the file list rather than the folder list because it is a secure folder. On a PC, seeing a shortcut instead of a normal folder is by design.
    If the vault is not opening correctly:
    1. Open OneDrive.
    2. Select Personal Vault.
    3. Complete identity verification using the offered method.
    4. If prompted that Personal Vault is not up to date:
      • Unlock Personal Vault.
      • Close any files stored in Personal Vault.
      • Wait for OneDrive sync to finish.
      • Then lock the vault again.
    If the issue is that files seem missing, note these behaviors:
    • Personal Vault files do not appear in OneDrive search results.
    • Deleted Personal Vault files only appear in the recycle bin when Personal Vault is unlocked.
    • In OneDrive.com, Show Personal Vault items in the recycle bin can reveal those items.
  2. SD - IA 178.9K Reputation points Independent Advisor
    2026-08-19T16:52:33.7133333+00:00
    It is the shortcut for everyone, so what you are seeing is normal.
    If you double click it, and authentication link will appear.
    I look forward to hearing from you to get the results of the troubleshooting.
  3. Craig Long 18,545 Reputation points
    2026-08-19T20:40:37.6633333+00:00
    The Personal Vault is hidden. Use the shortcut to unlock it. Then find the Personal Vault's location and size in its Properties. The shortcut won't tell you the size of the Personal Vault.
  4. SD - IA 178.9K Reputation points Independent Advisor
    2026-08-20T14:19:02.01+00:00
    I was asking a few questions to better understand the issue before recommending a solution. Please provide the requested details so I can continue troubleshooting.
