A Microsoft file hosting and synchronization service.
The icon shown has two distinct elements:
The small arrow in the lower-right corner is the standard Windows shortcut indicator.
The chain/link symbol on the folder indicates that the folder represents a shortcut/link to another location.
In the OneDrive context, a folder with the link/chain overlay can indicate a shortcut to a shared folder that has been added to OneDrive. This is different from the normal OneDrive synchronization-status icons.
For the list of icons and their descriptions, refer to https://support.microsoft.com/en-us/onedrive/what-do-the-onedrive-icons-mean
If the above response helps answer your question, remember to "Accept Answer" so that others in the community facing similar issues can easily find the solution. Your contribution is highly appreciated.
hth
Marcin
