Bing Places listing stuck in "Pending publish" for 3+ weeks, no response from placesfeedback
Bedis 0 Reputation points
2026-08-16T16:37:36.5366667+00:00
My business listing has been stuck in "Pending publish" status for over 3 weeks, well past the stated 7-12 day ETA. The listing is fully verified and synced with Google Business Profile.
I contacted placesfeedback@microsoft.com on August 7 with no response (checked spam, nothing there), and followed up again in the same thread.
Business Name: Dr Bouras Nesria Pédiatre et allergologue Store Code / Listing ID: 15831819731780373651 Address: Bardo center, Tunis, Tunisia
Could someone confirm whether there's a known ongoing issue with publishing right now, or advise on next steps?
Thank you.
Microsoft Advertising | Advertiser identity verification | Verify as a business
  1. MS Advertising - Arsen 160 Reputation points Microsoft External Staff Moderator
    2026-08-17T07:18:39.4466667+00:00
    Hello Bedis,
    Thank you for using our Microsoft Advertising Learn Q&A Platform!
    I sincerely apologize for the delay and frustration this has caused. I understand that your business listing has remained in "Pending publish" status for more than three weeks, which is well beyond the typical publishing timeframe.
    I will do my best to assist you with this issue.
    To start, we will need to investigate why the listing is currently stuck in Pending Publish status. Once we identify the cause, we will work toward getting your listing published as quickly as possible.
    Please note that there can be several reasons why a listing remains in Pending Publish, including but not limited to:
    • Data validation or quality review requirements
    • Publishing queue delays
    • Address or business information discrepancies
    • Category or content review requirements
    • Syncing or reconciliation issues between connected business data sources
    • Internal publishing system checks that require additional review
    We will carefully review all possible causes and determine the best solution for your specific case.
    I will also be sending you a private message so we can continue the investigation securely. Please do not post any account information, login details, or other sensitive information on the public forum, as this may expose your data and could result in the thread being moderated or removed for privacy reasons.
    Once we have the necessary account information through the private channel, we will be able to perform a more detailed review and determine the next steps toward publishing your listing.
    Thank you for your patience and cooperation. We look forward to helping you resolve this issue and getting your business listing published successfully.
    I hope the information provided here will at least partly answer your question.  If you have any additional questions please do not hesitate to reach out to our support. I have also sent you a private message asking for further details. You are more than welcome to respond to me so that I can begin the investigation on my end.
    Kind regards,
    Arsen D. | Microsoft Advertising Specialist | 800-518-5689
