Align folders in OneDrive Web and PC's File Explorer
Kristin Fan 20 Reputation points
2026-08-13T10:45:00.9833333+00:00
Why don't the folders in OneDrive Web and Windows File Explorer match? How should I organize my photo folders?
I'm trying to understand why the folder structure in my OneDrive web version does not match what I see in Windows File Explorer.
Some folders appear in File Explorer but not in OneDrive on the web, and I'm not sure whether this is due to how OneDrive syncs folders or because some folders were created locally on my PC rather than in OneDrive.
My biggest confusion is around my photo folders. I currently have four photo-related folders in File Explorer, and I'm trying to simplify and organize them properly. Here's what I've found:
1. Two "Pictures" folders
In File Explorer, I have two folders named Pictures, each containing slightly different subfolders.
One of them does not appear anywhere in OneDrive on the web. My assumption is that I should consolidate these folders and keep only the one that is already syncing with OneDrive and visible on the web.
2. "All Pictures" folder
I also have a folder called All Pictures, which appears in both File Explorer and the Files section of OneDrive on the web.
This folder seems to contain many of the same photos and subfolders as Pictures, but it also includes a Camera Roll subfolder.
It appears that Camera Roll is automatically receiving photos from my iPhone, and many of these photos also appear in the Gallery view.
Because of this, I'm wondering whether All Pictures is largely duplicating content that already exists elsewhere, and whether it could eventually be removed after I consolidate the Pictures folders.
Thankfully, Gallery appears to be consistent between File Explorer and OneDrive on the web (under the Photos tab).
This seems to be where my iPhone photos are being backed up and managed.
My ideal setup
Ideally, I'd like to end up with only two photo collections:
Gallery – containing all photos backed up automatically from my iPhone and visible under the Photos tab in OneDrive.
Pictures (or perhaps Past Pictures) – containing older photos or photos imported from other devices and sources. Ideally, this folder would not contain a Camera Roll subfolder if those photos are already represented in Gallery.
If possible, I'd also prefer for older photos in this second folder to be visible from the OneDrive Photos section as well.
Does this plan make sense, or am I misunderstanding how OneDrive organizes and syncs photos?
Can anyone explain why these folders differ between OneDrive Web and File Explorer, and whether the approach above would be a good way to organize my photo library without creating duplicates?
AI answer
2026-08-13T10:45:28.7533333+00:00
Yes, the plan mostly makes sense, with one important correction: Gallery/Photos is not a real folder. It is an aggregated view of photos stored in different OneDrive folders. That is why it can look consistent on the web while not behaving like a normal folder structure.
What explains the mismatch:
  1. OneDrive on the web shows the actual OneDrive folder structure under Files.
  2. File Explorer can show both synced OneDrive folders and other local PC folders.
  3. If a folder exists in File Explorer but does not appear on OneDrive on the web, it is likely a local folder that is not in the OneDrive sync location.
  4. The Photos/Gallery view collects photos from various OneDrive folder locations, so it does not map 1:1 to a folder in File Explorer.
For the photo folders described:
  • Two Pictures folders: keeping only the one that is actually inside OneDrive and visible on the web is the cleanest approach.
  • All Pictures: if it appears in both File Explorer and OneDrive on the web, it is part of OneDrive. If it contains the same photos as another synced folder, that indicates duplication.
  • Camera Roll: this is a real folder location that can contain uploaded phone photos.
  • Gallery/Photos: this is not a storage folder and should not be treated as one.
A practical way to organize this:
  1. In OneDrive on the web, go to Files and identify the folders that are truly stored in OneDrive.
  2. In File Explorer, compare those with what appears under the OneDrive location.
  3. Treat any photo folder that appears only in File Explorer and not on the web as a local-only folder.
  4. Consolidate older photos into one OneDrive folder such as Pictures or Past Pictures.
  5. Leave iPhone uploads in their existing OneDrive folder, such as Camera Roll, if that is where they are arriving.
  6. Do not try to organize photos by using the Photos/Gallery view. Use Files view or File Explorer instead, because photos cannot be moved from Photo view.
About the desired end state:
  • Having one folder for older/imported photos and letting phone uploads continue into Camera Roll is a workable structure.
  • Those older photos can still appear in the Photos section as long as they are stored in OneDrive, because the Photos view aggregates photos from various folder locations.
  • Removing All Pictures only makes sense after confirming it is truly duplicate content and not the only synced copy of some files.
Important caution:
  • If a folder is removed from sync on the PC by unchecking it in OneDrive settings, it is removed from the computer but still remains online.
  • Certain important folders such as Documents, Desktop, Pictures, and Personal Vault cannot be unchecked.
If the goal is to simplify safely, the best model is:
  • Use OneDrive Files view as the source of truth for what is actually in OneDrive.
  • Use File Explorer only within the OneDrive folder when reorganizing synced content.
  • Use Photos/Gallery only for browsing, not for deciding folder structure.
0 additional answers
