Hi Harold Aragon,
I understand how frustrating it is when your Surface Pro cannot connect to Wi-Fi, especially when the device is new. Just wondering, have you tried out the common troubleshooting steps in the AI answer yet, and what's the results? If the issue persists, it'd be helpful if you can confirm a few things:
- Whether the Wi-Fi completely missing/not working, or just cannot connect to TMOBILE?
- Whether you can see the TMOBILE entry in the Wi-Fi? And what exactly happen when you try to connect?
This is either a missing/corrupted driver, a frequency band mismatch, or hardware failure. The details above might help narrow down the problems, hence finding the most suitable solutions. In the meantime, below are some steps to fix typical Wi-Fi issues that you can try out:
- Press Win + X > Device Manager > select View > check Show hidden devices.
- Expand Network adapters > check if Wi-Fi driver is grayed out / shows a warning icon
- Click Action > Scan for hardware changes > check Wi-Fi driver again
- If that's not working, right-click the Wi-Fi driver > Uninstall > restart the PC.
- If the issue persists, connect your PC to Internet (Ethernet or Bluetooth tethering)
- Right-click the Wi-Fi driver again > Uninstall (choose Delete drivers... if prompted)
- Restart the PC. If it's not auto-reinstalled, manually install the latest drivers package:
- Visit Download drivers and firmware for Surface Pro | Microsoft Support
- Find your exact Surface edition > click the link to Download Center page
- Download the package that matches your Surface model and Windows version.
- Install the drivers and restart the device > check if Wi-Fi now works properly.
If none of the above helps and you still cannot connect to TMOBILE, please provide the details I asked for above. We then can check if there's a chance if there's something wrong with the Wi-Fi card not being detected by the system rather than a simple missing drive.
If you think the answer is helpful to you, please mark this as accepted. If you have extra questions about this answer, feel free to click "Add Comment" and ask!
Note: Follow the steps in our documentation if you want to enable and receive the related email notifications for this thread.
