An Azure communication platform for deploying applications across devices and platforms.
Thank you for the detailed guidance — this matches the format we used.
We had already submitted a CNAM registration request via email to the ACS telephony team on July 8, 2026, following this exact structure (company name, website, subscription ID, resource name, tenant ID, phone number, and caller name), but we haven't received any confirmation or status update since then.
Since the documented guidance says to open an Azure support request when no confirmation is received, we'll go ahead and do that to have the ACS team check the backend status. Just wanted to flag here in case others are experiencing the same delay — is there a typical response time we should expect before escalating, or any other channel worth trying in parallel?
Thanks again for the help.
